4 members (Hotrod Lincoln, jmoore, NorCal52Suburban, Donf), 183 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
#1595274 01/02/2026 8:47 PM
I'm adding Vintage A/C to my '56 3100 235 truck next month and need a dual grove pulley. I've started my search but not having much luck. I've posted in the "Parts Wanted" board.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
B Online: Content
The easy way (assuming your a/c compressor has 2 sheaves) is to run one belt around the crankshaft pulley, the water pump pulley and one of the sheaves on the compressor . Then run another belt from the other compressor sheave to the alternator.
H Online: Content
Check your PMs.
Crusty Old Sarge
Crusty Old Sarge
I have a similar pulley setup that Bill describes. I have a power steering pump and an alternator. I used a double row power steering pump pulley, and a single row alternator pulley.
I have a future project that will have A/C, Power Steering and an Alternator. I am adding a Harmonic Balancer from a 292, it has a 2 row pulley, also available with a 3 row. It needs to shortened a bit to match the 235 dimensions. This will give you the additional pulleys your after.
I used a bracket from POL (Performance On Line). There are several brackets available from Alan Groves Products.
235 Pulley Setup
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
H Online: Content
Trying to drive an AC compressor off the alternator slows it down so much that you won't get much cooling below highway speed. Use a 2 sheave harmonic balancer for a 250 six, and drive the compressor with the front crankshaft sheave. The balancer snout usually needs to be shortened about 1/4" to make the rear sheave line up with the water pump and the alternator. Machine the balancer OD seal surface back the same amount as you shorten the length.
