| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2024 Posts: 237 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 237 | 56, 3100, 235 Was there a single cable or two cables, ground terminal to frame and/or ground terminal to motor? Looking for what it was from factory.
1956 3100 three speed 6 cyl. Stock with a few upgrades. | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | My '57 LCF has a braided strap from the battery to the firewall behind the battery, and another from the lower part of the firewall/toeboard to the bellhousing at one of the starter bolts. Mine is a factory 283 V8. I have kept those straps in their original locations and also added a conventional stranded cable from the battery to a water pump bolt.
| | | | | Joined: Dec 2020 Posts: 1,965 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,965 | I have ground going from starter /bell housing to toe wall and battery. Both strap and battery cable. 4awg Strap from the battery to the upper firewall. I added a battery cable from the breather tube mount on the block to the frame of the truck From the frame to the bell housing. Never too much ground.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | Chevy used the "baby chicken" theory with those short braided ground straps- - - -"CHEEP- - - -CHEEP- - - -CHEEP!" It was a lot less expensive on the assembly line that way. Anytime another connection is added into a heavy current circuit there's a potential for loose connections or corrosion to happen. If you're building a "numbers-correct" show truck stick with the original stuff. Otherwise, run a piece of #0 welding cable for a ground from the battery to the engine block or the bell housing to carry starter current, and use smaller grounds to the body and frame for lights, ignition, generator/alternator, etc. Jerry
