| | | Forums66 Topics128,130 Posts1,056,712 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,393 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,393 | Curious how far your wipers sweep. When I installed my wipers I found that the sweep was only about 45 degrees so I needed to put the parked position up significantly from what you have in your pictures.
| | | | | Joined: Feb 2019 Posts: 4,496 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,496 | Curious how far your wipers sweep. When I installed my wipers I found that the sweep was only about 45 degrees so I needed to put the parked position up significantly from what you have in your pictures. I can answer that, something is not right with your current setup. My wipers on my ‘52, park at the cowl and sweep across most of the windshield, probably close to 120°.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Nov 2021 Posts: 1,393 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,393 | Phak1, thanks for the insight. I have looked at my setup (all replacement parts) and cannot see how I can get more travel but a lot of the parts are not readily visible so I may be missing comething. The amount of sweep is basically controlled by the length of the arm attached to the motor (electric in my case) assuming that there is not a lot of lost motion at the wiper arm pivot end. When my motor pivot is vertical (mid-travel) the arm pivots are also vertical the best that I can tell.
