Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (klhansen, 1955 1 Series, CuzzFuzz, Wally / Montana, 1 invisible), 57 guests, and 3 robots.
Topics128,003
Posts1,055,243
Members48,418
#1594922 12/29/2025 12:06 AM
B Online: Content
I was gifted with my brother Larry's Ridgid 15000 floor standing drill press. The chuck key that came with it does not fit the chuck properly. It is a sloppy fit and hard to use to get the chuck tight.
The hole in the chuck for the key is 0.330" as close as I can read it and the pin part of the chuck that I have that goes into the hole is more like 0.307".
The chuck will hold a 3/4" bit. I found a user manual with a parts breakdown that calls for a key with a part number of 817339.
When I called Ridgid they referred me to Gardener who told me they no longer stock the part. Did some web searching and found a number of references to a key with a part number of 817339. All but one said they were out of stock. The one let me order, then told me it would probably be a week or two before they would ship. We'll see.
Milwaukee's catalog has a key with the same size pin that I already have. Their next larger is bigger than the hole in my chuck.
If I were Jerry, I would solve this problem by making a sleeve that would be a snug fit on the pin with an OD of about 0.328", but I'm no Jerry. The wall thickness would be around 0.010".
I thought about the neck of a .308 caliber cartridge, but both the 308 and 30-06 have a neck diameter larger than 0.330. I guess I could try one of these and slit it length wise to let it collapse to the 0.330" size.
Suggestions???
Try Amazon they sell a assortment of,but read reviews for quality
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
B Online: Content
I looked at Amazon, but I couldn't find any with dimensions.
Sounds like you need a 5/16" pilot chuck key. I'm seeing one on Grainger's website LINK, so if you have a Grainger store nearby, they might have one in stock. That particular one says they could get it to me by Jan 2, so probably faster to Texas.
B Online: Content
A 5/16" pilot would only be .0055 larger than what I have now and would still be .0175 smaller than the hole. Too much slop I think.
One other option, though a bit more expensive, would be a new chuck (with key.)
Former Workshop Owner
Mc Master-Carr has an assortment of Chuck keys. If you click on product detail it will show a pdf detailing the pin size. It would be a big help if you knew the brand name of the chuck.
They also sell multiple size Chuck keys that are similar to a 4 way lug wrench.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I'd hate one of those. 75% chance of picking the wrong end. But you could mark it once you find the one that fits.
B Online: Content
I bought a "4 way" at Harbor Freight Friday. 3 were way to sloppy and the 4th wouldn't fit in the hole.
I just looked through all the McMaster-Carr offerings. The closest is the "A55" model at .312". Still about .018" smaller than the hole and only .005" larger than what I have now.
A neighbor just answered "yes" to an email that I sent earlier asking for a .308, 30-06 or 7.62mm spent cartridge. I'll try that as a bushing in the next day or 2.
H Online: Content
How is the chuck attached- - - -with a thread, or a Jacobs taper? I'll second the motion to replace the chuck, but getting a Jacobs taper off the spindle is a real challenge. There's a pair of slotted wedges that are used to remove that type of chuck, along with a big C clamp or a hammer and a backup weight. Unscrewing a threaded chuck is a lot simpler. Victor Machinery Co. (Victornet.com) has a good assortment of chucks at pretty reasonable prices.
www.ebay.com/itm/157537628402?
You could also grind that "too big" key shank down very carefully until it fits the hole in the chuck.
B Online: Content
Chuck is threaded.
B Online: Content
Went back and looked at the chuck for any identifying marks. None found. And I'm wondering if this isn't a "Jacobs Taper" like Jerry suggested. It has no method to hold the shaft while unscrewing the chuck.
Bond Villain
Bond Villain
Bill,
Over the years, I seem to have accumulated a small collection of chuck keys for which I have no particular application. I could send them to you to see if any of them fit.
PM me
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
B Online: Content
Thanks for the offer John. Let's see how it goes with plan C (a brass bushing) before depending on your stash. If we resort to your offer I'll only need keys with a pin size between 0.320" and .330 ".
If it's a Jacobs Taper chuck, it should have a slot in the spindle to insert a drift key. Crank down your spindle and take a look.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
B Online: Content
Didn't see anything I recognized as a "slot in the spindle".
Picked up 2 empty .308 cases and a 30-06 case. All three are a fairly snug slip fit over the pin on the chuck key, but have slightly too big O.D. to fit into the hole in the chuck. Plan for tomorrow is to take a bit off of the O.D. of the case until it fits, the super glue it to the pin.
H Online: Content
The groove in the spindle just above the chuck suggests that it's got a Jacobs taper. That's where the removal wedges fit. Spindles with a vertical slot in them are for removing tooling with the longer Morse taper. Jacobs tapers are very short- - - -one inch long or a bit less, with a much more pronounced taper than Morse. Use red LocTite, not super glue. It makes a much stronger bond.
B Online: Content
Use red LocTite, not super glue. It makes a much stronger bond.Jerry
Will do.
Busy tomorrow, it'll probably be New Years before I have time to mess with it.
H Online: Content
Here's a chart showing the usual dimensions of a Jacobs taper:
A lot of drill presses use a JT 33 taper. You can measure the diameter of the shoulder just above the top of the chuck to get an idea of which taper you're dealing with.
I stand corrected. Said Jacob’s, but I was thinking Morse.
Thanks for correcting me Jerry.
~ J Lucas
1941 Chevy 1/2-Ton
My Flicker Photos!
H Online: Content
Since I have a habit of making ancient machinery take on projects they're not really designed to handle at times, I've been known to make an adapter bushing to put a BIG drill chuck with a #3 Jacobs taper on a drill press that was designed with a 33 taper originally. I think Don has seen my drill press that was originally used in a 1960s high school wood shop- - - -now it's got two motors and a speed reduction system that has 12 spindle speeds instead of 4.
Bond Villain
Bond Villain
Originally Posted by Bill Hanlon
If we resort to your offer ...
So.... I'm a last resort, eh? That's fine. I can take a hint.
I really didn't want to break up my collection of chuck keys, anyway!
JM
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
BTW, last time I removed a tapered chuck was from laziness. Instead of changing out the tool holder in the mill, I put an end mill in the chuck. Afterall, it was just a quick/easy operation I needed to complete. Yep, that side pressure was just enough. Enough for me to not get the desired results and have to set up the job correctly.
B Online: Content
Success!
By the way, the off-center hole was there before I started. It held a spring loaded pin that served no purpose on this chuck.
H Online: Content
That spring pin on the key is to keep some minimum wage doofus from leaving the key in the chuck when he turns the machine on!
B Online: Content
Being a doofus 1st class, I'll put it back in.
I thought the spring loaded tee handle for my lathe chuck was a pain in the butt until I sent a 3/8" rachet at light speed across the shop.
I still remember a machine shop class in high school the teacher stressed to make sure the chuck was out of the lathe before turning it on .I guess the memory stuck with me after another student turned the lathe on with the chuck in and was very lucky he only got it graze his forehead and not in the eye .They should have had the spring loaded ones for the class .
"The Journey"
Follow in the DITY
Moderator
Moderator
2 Offline
I also graduated from a technical high school and took Machine Shop. Luckly, I did not learn the hard way to NOT EVER, leave any kind of loose items in or on a chuck.
Like Kevin, the instructor did a good job stressing that point. Gloves and any rings are also a big no-no along with loose jewelry, hair and clothes.
Listen and learn from the FOG's!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
H Online: Content
I learned the hard way not to use a pipe wrench braced against the ways and the machine in back gear/reverse to unscrew a rifle barrel from the receiver- - - - -who knew the first thing to loosen up would be the spindle thread on the lathe chuck?
Check first that the chuck is original. A replacement chuck can cause key fit issues.
If the right key never shows up, a thin sleeve will work. Brass or steel hobby tubing is usually close in size, or even a wrap of feeler gauge stock epoxied to the pin.
The cartridge case idea will work but likely won’t last long.
At that point, replacing the chuck with a quality 3 4 unit is the clean long term fix.
Moderated by  MNSmith
