1 members (Dusty53),
174
Mod | | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I am needing some part numbers for the AC six cylinder oil filters,had a local store see if they can get them and got sticker shock so I need some numbers to look at when I go to swap meets. | | | | | Joined: Sep 2010 Posts: 2,310 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,310 | What is the number for your filter that you use now. I would try were you are a tractor supply as they most likely have them as regular stock as a lot of tractors use a canister filter. I was using a fram c4 krawlinator k55 and Napa filter ,the fram I got from the Canadian tire had a few in stock for about 6 bucks so I bought them all as the Napa gold was getting up there about 20 bucks and the krawlinator I used to get the place closed . You should be able to put the number of the filter and brand into a cross reference chart and the other brands will show up and look from there at what is a good price and available. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 |
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The last one I used before removing the filter was a NAPA 1100 | | | | | Joined: Oct 2021 Posts: 6,805 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,805 |
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I will have some Fram filters coming off Amazon,I can get four for what the local parts stores wanted for one. | | | | | Joined: Sep 2020 Posts: 451 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 451 | Yes I have bought the Fram filters as well, however, gaskets came creased, and wrong diameter for my housing lid….might as well include gasket at all. Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | |
