3 members (hardshell, klhansen, ShopRag), 44 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#1594820 12/27/2025 1:04 AM
I am needing some part numbers for the AC six cylinder oil filters,had a local store see if they can get them and got sticker shock so I need some numbers to look at when I go to swap meets.
What is the number for your filter that you use now. I would try were you are a tractor supply as they most likely have them as regular stock as a lot of tractors use a canister filter. I was using a fram c4 krawlinator k55 and Napa filter ,the fram I got from the Canadian tire had a few in stock for about 6 bucks so I bought them all as the Napa gold was getting up there about 20 bucks and the krawlinator I used to get the place closed . You should be able to put the number of the filter and brand into a cross reference chart and the other brands will show up and look from there at what is a good price and available.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I use WIX 51100
Craig
The last one I used before removing the filter was a NAPA 1100
Hastings / Baldwin LF373
1950 Chevrolet 3100 (Ol' Roy)
I will have some Fram filters coming off Amazon,I can get four for what the local parts stores wanted for one.
Yes I have bought the Fram filters as well, however, gaskets came creased, and wrong diameter for my housing lid….might as well include gasket at all.
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
