7 members (farmallb, Samantha, Opelika Tom, Oswald, Hanks custodian, 2 invisible), 79 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1594777 12/26/2025 2:50 PM
I
I Offline
I have a pin hole leak in bottom of oil pan that I can weld up, but there is a bunch of rust pitting in bottom of pan. I have used por15 tank sealer with success on fuel tanks, but has anyone on here used this on an oil pan?
53 chevy 3100
IHPWR #1594796 12/26/2025 7:17 PM
I had some minor pitting near the drain plug on my oil pan, none all the way thru. I sandblasted the area and filled the pits with JB Weld. Have never used POR15 tank sealer on anything. I don't think that a gas tank that needs to be sealed should be used at all.
IHPWR #1594798 12/26/2025 7:51 PM
Just cut the bottom out of the pan with a cutoff disc in an angle grinder and weld in a piece of 16 gauge mild steel sheet metal to replace it. (NOT galvanized!)
www.ebay.com/itm/116195691101?
I use an acetylene torch for that kind of repair- - - - -bolt the pan to a core block to prevent warping it while you're welding.
