0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#1594602 12/22/2025 10:35 PM
I have been reading about our 216 and 235 engine oil Should we be using non detergent oil wit zinc additive.
1955 second series 3200
I wouldn't use it, unless you think your engine has 70 years of gunk solidified in your engines nooks and crannies that might be dislodged if modern detergent oil is used.
The only person I personally know who uses non detergent, straight weight oil in certain of his classic cars does so in a couple J model Duesnbergs and Packards of the 1930s that have their original engines that have never been rebuilt and have had non detergent oil since day one.
The rest of the vehicles in the collection, where worries about dissolving impurities in the crankcase aren't a concern, use modern detegernt , multi-viscosity oils.
I wouldn't use zinc additives, either. You can't control how the additive is blended with the oil or in what ratio.
If you really want a high zinc oil for your engine, The Classic Car Club of America has contracted to have oil produced to its own specifications for use in antique car engines. It has 1600 ppm ZDDP, which is about the highest zinc content of any oil you'll find, including the VR-1 racing oils.
www.inrccca.org
1950 Chevrolet 3100 (Ol' Roy)
It seems that zinc is only important during camshaft break-in on a flat tappet engine. Once that original wear pattern is established, the zinc concentration becomes much less important. The retailers of "high zinc content" oil have found a good way to pick the pockets of gullible people, I think! It's sort of like the folks who tout other "mouse milk" oil additives like STP, etc. I attended a seminar several years ago hosted by a research chemist for Kendall Oil Co. and the question was asked about "additives". His answer went something like this: "We use 22 additives already- - - -17 of them are beneficial to your engine, and the other five offset the bad effects of those 17! That's good enough for me!
Like pouring water into good whiskey.
BC
1960 C60 pasture art
I
I Online: Content
Watch some you tube videos with Lake Speed JR., now with total seal piston rings. He will educate you on all things oil, the good and bad. His videos are very informative.
53 chevy 3100
Thank you so much for all the feed back. Merry Christmas
I also highly recommend Lake Speed Jr’s YouTube series on everything oil. He has the science and facts to back up everything he posts.
