2 members (Stewart2, 1 invisible), 58 guests, and 7 robots.
Topics128,014
Posts1,055,324
Members48,419
#1594259 12/15/2025 5:44 PM
I need help to ID a 5 speed transmission I recently acquired.
Borg Warner Casting numbers: Case 13-38 065-901, rear housing 13-38-007-902
Std GM bellhousing mount, oblong shaped aluminum case with ribs, 10 spline input shaft,
mechanical speedometer drive, shifter located at rear of housing.
It's not a T5 best as I can tell as the numbers don't correspond with the 1352-000 series.
I didn't give much for it and it looked interesting.
I thought it could be from A LUV Truck (Isuzu) but couldn't find much reference to a
5 speed, only a 4 speed.
Any assistance would be appreciated.
Fred
rfs56trk #1594261 12/15/2025 6:07 PM
AI comes back with that number as a 4 speed. Predating the T-5, apparently.
"The Borg Warner 13-38-065-901 is the part number for an aluminum-cased, 4-speed manual transmission commonly used in classic GM vehicles from the 1970s, such as certain Chevy Nova, Camaro, and Cosworth Vega models, serving as a robust replacement or upgrade for period hot rods and performance cars."
rfs56trk #1594271 12/15/2025 9:56 PM
Thanks Kevin,
I went back and did a sanity check. It's in really nice shape, shifts and turns freely.
I was able to engage 5 forward gears and reverse by turning the input shaft.
Somehow this one got missed in final inspection.
Fred
rfs56trk #1594299 12/16/2025 1:59 PM
Fred - Seems you've found what some folks call the predecessor to the T-5. It's actually a Borg Warner T-50 5 speed OD transmission. See the snapshot below for some generic info on the transmission. I actually drove a late '70s Chevy Monza with this 5 speed. It was well suited for that little thing, but I have my doubts about use in a truck. It's also hard to find parts for if it needs repairs/rebuilding IIRC.
Here's a link to an old article by some folks that have a lot of info on T-5s also online.
~ Dan
1951 Chevy 3 window 3100
rfs56trk #1594312 12/16/2025 4:25 PM
Thanks Dan,
Hopefully it will be useful to someone.
I also picked up a stubby 3 speed with a Corvette close ratio gear set
and a HD truck 3 speed.
There is a gold mine of Pontiac racing goodies and a Richmond 5 speed
at the same location but that's a story for another day.
Fred
rfs56trk #1594323 12/16/2025 6:11 PM
Originally Posted by rfs56trk
There is a gold mine of Pontiac racing goodies at the same location but that's a story for another day.
Fred
I hang out on a Pontiac enthusiast's web site (left over from my '57 GMC which came from the factory with a Pontiac V8). I'd be happy to post the Pontiac info over there and see if there is any interest.
rfs56trk #1594350 12/17/2025 5:03 PM
Thanks Bill, I sent you a PM
