4 members (kbenz, cmayna, Cletus1950, 1955 1 Series), 94 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
Hate to bother with another silly question but I've tried to do my own research with you tube and in general google searches to no avail. What is the correct spec brake fluid used in '78 for Chevy Suburban, big block with disc brake front only if it makes any difference. Thanks in advance. P.S. Have a merry Christmas all!
Yours probably came from the factory with Dot 3 brake fluid which is suitable for your drum/disc brake setup. If you are worried about the brakes getting high usage (heavy regular braking that might cause excessive heat in your components) then you might consider upgrading to Dot 4 which from what I recall is meant to withstand higher temps. Since they are compatible fluids, no need to completely flush the systems unless your concerned about debris or contaminants.
Everything I've read says DON'T use Dot 5 unless your equipment and operation demand that. The fluid is silicone based, which is not compatible with nor will it mix with Dot 3 and 4 fluids. Switching to Dot 5 requires complete flushing of the brake systems as well as replacement of some components that flushing the system can't completely remove the Dot 3 or 4 fluids completely. My understanding is it's very costly and unnecessary for regular vehicles usage.
Merry Christmas back at you! wink
~ Dan
1951 Chevy 3 window 3100
Insomniac
Insomniac
Service manual says "Delco Supreme 11 fluid or DOT 3"
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for the quick replies! I even bought a factory service manual for a 1978 Suburban, after receiving it realized it was for "unit" rebuilding. Transmission, rear end, brake master booster etc. Not much usable info that I needed. Got exited about finding a factory manual instead of a Chilton's etc. and didn't read closely enough.
DOT 3 and 4 are compatible with each other- - - -the DOT 4 just has a higher boiling point. That's useful if you have disc brakes and tow trailers, etc. Either one can be used for light to medium duty applications.
Thanks Jerry, I wanted to get a good answer here instead of going to O'Reily's counter to ask. Comfort level not high enough there.
