| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 228 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 228 | Greetings. Converted my 51 GMC 252 ( 1 ton) from a 228 to a military 302 .
Originally used the early lower radiator connection tube from the 51- 228. 302 Engine has the short shaft water pump.
This original metal pipe with 1 1/2 inch connectors fit but was a quite tight making the connection from the water pump to the lower connection of the radiator due to the compound angles. Bought a replacement in a molded hose for the early motor and one for later 50’s and neither fits correctly.
Are there any other applications that may fit my configuration? What did you do.? Thanks | | |
