7 members (Wayne67vert, 32Fordpuchoptop, Peggy M, mo2cyl, Stovebolt48, tclederman, asilverblazer),
177
0
Mod | | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 27 Junior Member | | Junior Member Joined: Jan 2007 Posts: 27 | I Tried a tip from one of the Model A web sites on what to use as a cleaning fluid and it worked better then I expected. Paint Thinner! Just under $2.00 a gallon,140w gear oil dident stand a chance with this stuff. Varosol is $8.50 a gallon now. Give the paint thinner a try! Wick
Every Hour you spend Fishing adds A Day to your Life!
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | paint thinner and Kerosene great parts cleaners , the Kerosene has a lower flash point but with care both work great ! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Where ya all finding paint thinner (mineral spirits) for $2.00 a gal Wick?? Any big box stores?? I use Kerosene and I try to use gloves when ever I wash parts but they spring a leak once in a while and some times I'm just in to much of a hurry and go skinny dippin'. If I'm in there to long my hands get numb and start to tingle the same as they used to do with gasoline years ago. I think the Kerosene has additives in it that taint so good absorbed through the skin. But it is about the best around. I used some safety clean once and I think its basically mineral spirits. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Put some (about a quart for 5 gals of kerosene)ATF in the kerosene and it will take some of the bite out of it wothout affecting the cleaning ability, done this with the Safety Clean and worked well also.
You Learn more Listening than Talking
