4 members (Otto Skorzeny, Hotrod Lincoln, TUTS 59, jmoore), 138 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#1593230 12/01/2025 9:48 PM
Was looking for the lug nut torque on my old '66 C60 today...found it in the owners manual. Spec for flanged one-piece nuts is 3-400 ft/lb.
The strange thing is I measured the wheel stud thinking they would be either 5/8 or 3/4" but no....they're 11/16 dia.
Never heard of studs that size and Mr. Google doesn't seem to have heard of them either.
G508 #1593242 12/02/2025 12:06 AM
Big Bolt Forum Co-moderator
Not saying these are for your application, but I found sone studs that are 11/16" diameter. https://www.amazon.ca/Dorman-610-158-Length-Thread-Serrated/dp/B000DCNT08
1948 Chevy 2-Ton
G508 #1593260 12/02/2025 3:06 AM
This screenshot from a 1966 Chevy Master Parts Book for Medium/Heavy Duty trucks shows your 1966 C60 came with 11/16" wheels studs/lugs. Granted this is just specifically ID'ing the front wheel studs, but the rears would be the same diameter. Note that they are left and right hand thread per the descriptions.
~ Dan
1951 Chevy 3 window 3100
G508 #1593280 12/02/2025 2:08 PM
Interesting that they still list them as having RH/LH studs. Mine has all RH studs. It also has the dreaded "widow maker" split rims. I replaced the two front rims with 22.5 solid rims made in Turkey. I'd replace the other four but last time I looked I couldn't find them. Anyway they would cost more than the truck is worth at this point.
G508 #1593285 12/02/2025 3:16 PM
Buy truck wheels.com has what you need but they are high priced.
G508 #1593763 12/08/2025 6:42 AM
I got all six of my 22.5" wheels there too, and it cost me $1800 including shipping. Buy once, cry once as they say. They're 20lbs apiece heavier than the Accu-Ride repops from the late '90s, but those are also scarce as hen's teeth nowadays. A new wheel you can buy is better than the old one that you can't.
Anyway, it's a great way to get into tires that are modern and easy to source-and also that tire shops will work with because the new rims don't have the habit of exploding, and killing tire techs.
The only downside to the new rims is they're 3/64" thicker than the originals, so you might need new lug studs on the rear axles.
RH5 were by far the worst but any of the muli-piece wheel can kill!
BC
1960 C60 pasture art
