3 members (Hotrod Lincoln, Otto Skorzeny, MNSmith), 77 guests, and 3 robots.
Topics128,087
Posts1,056,338
Members48,442
Page 2 of 2 1 2
H Online: Content
Coast/accelerate, and get a puff of blue smoke- - - -sloppy valve guides and/or bad intake valve stem seals. That same leak test adapter can be used to change valve seals while you hold the valves closed with air pressure- - - -just be sure not to release the pressure with the valve springs removed! Dropping a valve into a cylinder usually means removing the head. Another way to do a "head on" valve seal replacement is to pack the cylinder full of 1/4" nylon rope through the spark plug hole, push the piston tight against the packing, and change the seals.
www.ebay.com/itm/405882268688?
Thanks, I hate to pull the head!
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Page 2 of 2 1 2
