6 members (rfs56trk, frogfarmer, Bill Hanlon, 50Chevy3100, Buckeye998, JoergK.), 369 guests, and 2 robots.
Topics128,160
Posts1,057,054
Members48,463
If you have a set of ‘32-‘36 car or ½ ton truck rear motor mounts that need to be revulcanized, you will be shocked when you see the price. Filling Station wants $300, and I only found one other place that charges $250. There are no aftermarket replacements as far as I can tell, as the set the Filling Station used to sell haven’t been available for many years, and they tell me they have no hope of them being available again.
As some of you know, fellow Stovebolter klhansen (Kevin) has successfully “revulcanized” several parts for himself, and was kind enough to share his process here. I took inspiration from him to try his process on one of my motor mounts, thinking it’s at least worth a try before spending that kind of money. If it works, it’s $38 and some time versus $300.
I will explain how I did mine, and then how I think you SHOULD do it if you want to give it a try. I think my way was successful, but after doing it I also believe a different way (which was also a suggestion from Kevin) would be better.
HOW I DID MINE: These mounts have openings and holes of various shapes and sizes that need to be plugged so the liquid resin doesn’t run out. The mounts consist of two pieces of steel. The part that bolts to the bell housing has two “wings” that float inside the rubber, which is contained by the second outer piece that bolts to the cross member. You need to find a way to make a jig or a mold to not only plug all the holes, but also hold the two pieces at the proper location.
Luckily, one of my mounts was still good, so I could use that one as a guide. (the bad one become oil soaked which is what I think ruined it) I decided to use Gorilla tape as my “mold” to plug all the holes. You also need to make sure the resin doesn’t run into the center and clog up the mounting holes, so I used tape to form a barrier in there too. I bolted the mounts back-to-back, with the good one mounted to a 2x4, and the bad one hanging off the edge. I found two nuts that were about the right thickness to set the height of the wings inside the outer piece. I just adjusted it to where it needed to be (up and down, fore and aft) and let gravity hold it there on top of the two nuts.
I did two separate pours. I did he bottom first, and let that harden so I could then remove my spacer nuts before doing the top. I also used a bolt with a nut on it through the bottom cross member hole to keep the hole clear in case any resin leaked down into there, which a tiny bit did. The one downside of this was I couldn’t quite manage to get the nuts back out since I couldn’t lower the wings enough to do so after the bottom had been poured. I just had to cut a piece off of them with a dremel, then I could pull them out easily. Not a big deal, but this won’t be necessary if you do it one of the ways I suggest below. I inserted the resin with a syringe into some of the openings that I didn’t cover with tape. For the first pour, I pretty much only taped to the height that I needed to in order to contain resin below, and up to the wings.
After the first pour was done, I added more tape to the height necessary to contain the resin that needed to be put in above the wings. I just used the syringe again to slowly squirt the resin in right on top of the wings to the top of my tape. The whole process worked very well.
HOW I WOULD SUGGEST DOING IT : Kevin and I exchanged a few ideas through email before I did this, and he suggested trying to use clay as a mold. I didn’t have any clay the day I decided to give this a try, so I went ahead with my tape method, figuring I’d try the clay if the tape didn’t work. I think clay would have been easier, as you could probably just plug all the holes with it, plus you could also form a clay “cradle” to hold the outer piece at the proper place without using nuts like I did. Or you could make some other type of jig, perhaps a piece of wood cut to the proper height to screw the outer piece to.
Any of these methods would also allow you to do one pour, as you wouldn’t need to remove the nuts before pouring the top. Or you could pour one complete side, then the other. Whatever you think is best. I just did what first came to mind while standing in my garage looking around at what I had laying there. I’m sure there are better, more creative ways to do this with some thought. Whatever you think would be easiest. I looked on Amazon and saw that clay comes in types that harden, and some that don’t. I would probably try the stuff that doesn’t, as I’d be worried the type that hardens might shrink, or not stick to the metal, allowing possible leaks. But I have no experience with clay so can’t say for sure either way.
OTHER THOUGHTS: I used a torch to remove the remaining rubber from the bad mount, then cleaned as much debris and soot out of the mounts as I could with whatever I had that could reach into that tight area. If you have access to a sandblast cabinet, you may want to sandblast the mounts inside and out. I didn’t do that. I did also cleaned mine with acetone, and it appears as though what I did was sufficient. I seem to have a very good bond. You have a 7 minute work time, and it flows and self-levels pretty well after first mixed, and then gels up quickly. It’s pretty easy to work with, and if you screw it up the first time, you probably have enough for 15 to 20+ more tries.
The product (Simple Resin Enduro Flex) is claimed to be good for bushings, and Kevin has used it successfully for his applications, but only time will tell if it holds up to the weight, torque, and vibration of an engine. Now that it’s done, I’m much more confident that this will work than I thought I would be. Fully cured, this stuff seems at least as firm as the rubber in the good mount.
Attached are some pictures I took through the process, hopefully in this order: 1.) Bad and goods mounts before I started. 2.) Bad mount after torching rubber out, with 2nd metal piece that lays in the bottom 3.) Using nuts as spacers to set the height and position 4.) The first tape job and pour 5.) Second pour with additional tape 6.) Mount after tape was removed 7) Mount after trimming some of the excess with a razor blade
Link to Simple Resin Enduro Flex:
https://simpleresin.com/product/enduro-flex-flexible-resin/
Nice job, Ron.
As an FYI, I forgot to mention when we e-mailed about it is that I used some black colorant for epoxy. That makes them look a little less anemic. wink That light color of the material just didn't look right to me. We've also cast some fishing lures with the stuff and used fluoresceent dye. That may be something that the hot rodders might like. grin
It'll be covered in road grime and oil in no time so the anemia won't last long.
1950 Chevrolet 3100 (Ol' Roy)
I was wondering if spray paint would stick to it, or harm it's integrity in any way. I have to clean them both up and re-paint them so I'm going to give that a try. If it sticks, fine, if it doesn't, not the end of the world. But thanks for mentioning that for the next guy who may wish to try this. Would definitely look better with some black colorant.
Moderator, Electrical Bay
You can also use Devcon Flexane 94 and make all kinds of motor mounts and transmission mounts. Flexane 94 is more costly than $38 but it makes a great rubber motor mount and you can also use it for lots of other things. Being a higher shore rating (shore rating of 97), it will stand up to about any amount of vibration, torque, etc you can toss at it. The last time I used this I made a plaster mold (2 piece splittable mold with "pour-in" holes) and stripped the old rubber off the metal pieces, cleaned them up really well and then just mixed the stuff, poured it in and let it cure overnight. Not to brag but it looked just like a new mount. The mount was for a 1956 Cadillac and at the time there were none of the motor mounts I needed being made or even available. The last I heard it was still fine after 15+ years of use. With a one pound kit you'll have enough to make shock absorber grommets, driveshaft collar pads, body mounts or grommets...anything your imagination can consider and for which you can make a mold. You can also get Flexane 80, 87 and 90 which are all slightly softer. Just shop around. You'll find some variations in pricing. One hint: get all your projects lined up and molds made at one time. Flexane cures after about 5 or 6 hours and it is best if you can do everything you need at one time.
~ Jon
Wow Jon, that '56 Cadillac motor mount you made must have been a really long time ago. I was able to buy new ones 20 years ago.
Is this stuff easy to work with? I will have to make note of this in case the Simple Resin doesn't work out.
Yes, it is easy to work with. You make a mold out of plaster of Paris in 2 parts so it can be separated, let it dry well and coat with a release agent. Then you mix two parts, pour it through the holes you made in the mold (two...one to pour into and one to let the rubber flow out the other end) and it cures into black rubber...as hard or as soft as you wish. As I recall you have about 10 minutes to pour the rubber formula in before it starts to set. Dead simple to make molds. Just remember to set pins (dowel rods with beveled tips work well) in the first half and also spread a release agent over everything so you can separate the two halves. I make a small box out of cereal box cardboard to make the mold in and then just tear it off when the plaster is dry. DO NOT USE WALLBOARD COMPOUND AS A SUBSTITUTE FOR PLASTER OF PARIS. Sorry for all caps but wallboard compound will not dry like plaster will and even when it does dry (very long time) it won't work because it usually changes dimension and cracks internally. It is completely different in composition and performance. If you do a good job with your mold, you can re-use it as many times as you wish. Actually I discarded the Cadillac motor mount mold around 5 or so years ago.
Do you know the shore rating of the enduro-flex you used? 90 to 97 shore will give you plenty of strength and will still dampen noise. Anything with a rating down to around 80 (shore A) ought to be okay. I would not use anything below that, however.
The Cadillac mount was one I made around 1992 and at that point I could not find one anywhere. I should mention at that point a pound kit of Flexane was around $25. I see the mount has been re-produced since then. This is what it looked like and one of mine had broken (the engine would lift up off of it when rpms were increased):
https://www.caddydaddy.com/1954-195...production-free-shipping-in-the-usa.html
~ Jon
Enduro Flex cures to a hardness of 80 shore A. I used it for the axle pivots and it holds up well.
It's weird for me to think of 1992 being a really long time ago but I guess 33 years actually is a long time.
Yeah, back in that era, the T170 axle I swapped into this bus, was the modern option-you could still buy a ring and pinion for it at the dealer.
I wish I had, because now it's just as obsolete as the original T150 that it replaced!!
