| | | Forums66 Topics128,089 Posts1,056,352 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Coast/accelerate, and get a puff of blue smoke- - - -sloppy valve guides and/or bad intake valve stem seals. That same leak test adapter can be used to change valve seals while you hold the valves closed with air pressure- - - -just be sure not to release the pressure with the valve springs removed! Dropping a valve into a cylinder usually means removing the head. Another way to do a "head on" valve seal replacement is to pack the cylinder full of 1/4" nylon rope through the spark plug hole, push the piston tight against the packing, and change the seals. www.ebay.com/itm/405882268688?Jerry
| | | | | Joined: Aug 2015 Posts: 806 'Bolter | | 'Bolter Joined: Aug 2015 Posts: 806 | Thanks, I hate to pull the head!
1953 Chevy 153A 3/4-tonWorking on my project since 2015Follow along in my DITY | | |
