6 members (Rusted Nut, Lightholder's Dad, Bill Hanlon, Hotrod Lincoln, Buckeye998, 1 invisible), 87 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
#1592555 11/23/2025 12:49 AM
I have 7.50-17 tires on a ‘53 3800 pickup. I was looking for some more aggressive tires for the back, and saw some nos 8.25-17 nearby. Anyone ever use this size? They seem pretty uncommon.
Is this the type of tire you're looking at???
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1592605 11/23/2025 6:58 PM
Yes it is. The only other traction type tire I see for these trucks is the tornel traction in 7.50-17. These nos tires are much much cheaper.
Pa Farmer #1592624 11/23/2025 10:09 PM
What is your rim size? The 1953 Chevrolet Truck Data PDF shows 2 rim sizes for 1953 3800's. 17 X 5.0" is the standard width listed for 3800 with a special 17 X 6.0" rim for 3802 models (Flat face cowl).
A chart I came across looking for tire width to rim width limits suggests the 8.25 tires need a minimum 6" wide rim for safe mounting and operation. Hope this is of help in answering your question.
~ Dan
H Online: Content
When were those "NOS" tires made? If they're more than a few years old, they're no bargain. Tires have a definite "shelf life", even if they're never inflated.
Pa Farmer #1596327 01/20/2026 12:46 AM
It appears to be a nylon tire. Age doesn't affect nylon tires much. I install worn out nylon tires on storage trailers because don't blow out like radials. However, if the guy only has one of them, you may never find one to match it. We used 7.50x17 on our pickups back in the 1950's and 1960's. 8.25x17 were in the price books back then, but I'm not sure I ever actually saw one. I have a couple of old pickups with 17" wheels. Next time I put new tires on my 3500HD I plan on putting radial tubes in the old tires and use them on my old pickups.
Age may not affect the nylon cord, but the rubber sure does go bad. I've seen nylon cord tires that are cracked and brittle.
Moderated by  Dusty53
