1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#15926 08/25/2004 12:18 AM | Joined: Dec 2003 Posts: 11 Junior Member | | Junior Member Joined: Dec 2003 Posts: 11 | I have a "46" pick-up that is getting a complete restoration. I bought a radiator mounting gasket kit from "Chevs of the Fourties". It consists of four rectangular rubber pieces. Two of the pieces have holes for bolts and two of them have slots that appear also to be for bolts. Do they go between the radiator and the frame? All of them? In what order? The bolts that come with the mounting kit are carriage bolts. Are they meant to go up from the bottom with lock nuts and washers on top or the other way around? Any help would be appreciated :confused: | | |
#15927 08/25/2004 6:03 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | Ritchie,
Radiator support gaskets are shims used to adjust the front clip fender assembly that attaches to the radiator support. No order is used. The slotted ones are installed or removed easily as needed to adjust the front clip.
Set the hood first, then raise the fenders to fit the hood using the shims under the rad. support. Also the fenders will move independently up and down at the attaching point on the radiator support as needed.
Carriage Bolts drop in from the top.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
#15928 08/26/2004 12:06 AM | Joined: Dec 2003 Posts: 11 Junior Member | | Junior Member Joined: Dec 2003 Posts: 11 | Thanks "HOT ROD6" - now that I have the benefit of your input it seems simple enough. Thanks for the help. Rich | | |
