The bolts are the same diameter 3/8" coarse thread, but there may be some slight differences in length. I've seen manifolds that have different height ledges where the clamps fit, so would need shorter or longer bolts, mainly at the end bolts. Here's a picture of the manifold on my 216. Note the long bolt on the rear position.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
My '46 216 and '60 235 were different on the first and last manifold bolts. The 216 had a thick washer and was close to the block. The 235 had a longer bolt and a metal cup type retainer.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engine Here We Go Follow in his DITY Bay
John has illustrated what I recall. I have a short bolt manifold that came off a 46 216, but the one on my '51 216 had the longer bolt like John shows on the '60 235.
As long as the bolts aren't badly corroded, they should be OK to use.
John, maybe it's the angle of the picture but does the manifold of the 235 stick out a lot farther from the side of the engine than that of the 216?
1950 Chevrolet 3100 (Ol' Roy)
Ok. The two pics side by side from different angles made the 235 appear to extend further out.
