4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
Just want to inform about my experience. I found a source for Frantz as I wanted to replace the rubber "o-ring" and saw they had filters. I thought "This is better than the John Wayne toilet paper those guys on Stovebolt suggested." So I ordered 4 of their "cellulose" filters you can see here: https://www.frantzfilters.com/product-tag/parts/?orderby=popularity
Well I got my order yesterday and I'm here to tell you what I bought was FOUR ROLLS OF JOHN WAYNE TOILET PAPER!!!!!! At least the hole in the center is the correct size for the center of my oil filter and the o-ring is a perfect fit
1951 GMC with positive ground. Engine is a ‘54 Chevy passenger car (Serial Number 0024472F54Z) with a ‘56 head (casting code on top of head 3836848 GM 4), Casting Code (on passenger side on side of head B56 848 850)
Isn't the Frantz oil filter's entire raison d'etre is that it utilizes toilet paper?
1950 Chevrolet 3100 (Ol' Roy)
1 Offline
I buy mine at Costco. Of course we use it in the house too.
1951 3800 1-ton
In the DITY Gallery
H Online: Content
The original Frantz system used a regular Fram or AC canister with some adapter bits and pieces. Buy a case of TP from the local "No Tell Motel" and you'll be good to go for a long time!
