7 members (Mike in Sycamore, Leo, Gdads51, 1955 1 Series, Bill Trotter, cmayna, ShopRag), 109 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
Hey team - Are the headlight buckets, retainer, & chrome bezel ring the same for the 1.5 & 2 ton trucks? I assume they would be, but I haven't found anything that concretely says so. Compatibility tables online (when available) seem to stop at 3800. The chrome bezel rings that came on the old farm truck had notches for headlight adjustment - something I don't see on most other AD trucks, so I'm not sure they're the appropriate ones. Thanks for your help!
Headlight Chrome Bezel Trim 1.5 Ton 2 Ton
1947/1948/4199 Chevy 4100 Dump Truck - 1.5 Ton
Follow the build in BIG BOLTS
Big Bolt Forum Moderator
As far as I know, they are all the same, regardless of the weight class. (at least on the Taskforce era, 1/2 ton up through 2 ton are all the same)
Mike
According to the parts manual the trim rings are all the same for AD series trucks. I suspect someone cut those notches in that one. The passenger car trim rings were stainless steel and will fit. Identical except for material.
Great, thanks for the info! I suspected they would be for simplicity sake. It looks like these notched bezels were used on other cars & motorcycles (from a reverse-image-search).
