2 members (1955 1 Series, Otto Skorzeny), 159 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#1591639 11/09/2025 11:51 PM
A couple of questions:
Can I take a Carter carb from a 235 engine and install it on a 216 engine? The carb is from a 1955 235 and install it on 1948 - 1950 216.
What alterations would be required?
The spacing of the carb flange bolts are different, as well as the throttle throat size. The 235 carb is slightly bigger, and calibrated for the larger displacement engine. You could hog out the holes in the carb and make it bolt on, but possibly a better solution would be to use the 235 intake manifold assuming you have one.
You’re talking a Carter YF?
The 216-sized YF’s are easy to find compared to the 235 variants, and cheaper.
1951 3100
Carburetion specialist
Not sure there is sufficient room on the 235 throttle body to hog out the mounting holes.
One could fabricate a tapered adapter to allow the fit.
One could either use a 235 intake manifold or fill, redrill, and retap the mounting stud holes in the 216 manifold.
I do not know the diameter of the fuel / air hole in the 216 intake; it might be necessary to hog out this hole to match the larger throttle body.
The 235 carburetor would REQUIRE recalibration for use on the 216. Probably a metering rod and main jet; would have to guess on both, you might end up buying more than one.
As Nathan stated above, 216 YF's are much more common than those for a 235. I am certain it would be easy to make a trade for the 216 carburetor.
If no one else reading this will do so, I will make such a trade; in fact, if you have a rebuildable 2100s, I will trade you TWO 216 YF's for it.
Jon
The Carburetor Shop
