2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2025 Posts: 42 'Bolter | | 'Bolter Joined: Aug 2025 Posts: 42 | Hello all,
I am trying to remove the rear axle oil seal and cannot get it out. I am using a seal puller, but so far all I've done is deform the seal.
Any suggestions? | | | | | Joined: May 2015 Posts: 11,152 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,152 | Just tear it out, it can't be reused anyway. Use a slide hammer with a hook on the end. Just be careful not to hook the axle bearing.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2025 Posts: 42 'Bolter | | 'Bolter Joined: Aug 2025 Posts: 42 | I eventually got it out. Really destroyed the thing.
Thanks. | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | A small shepherd's crook pry bar has always worked well for me, or a big "heel bar". Yes, it destroys the seal in the process. Jerry
