| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2025 Posts: 50 'Bolter | | 'Bolter Joined: Aug 2025 Posts: 50 | I'm not sure how many of you have tackled this, but thought I would get your ideas. I acquired this 1956 Chevy 3100 this past summer. I have begun restoration such as removing hood, grill and one fender to start sanding. Although the body is in great shape there is SO MUCH surface rust I am finding the sanding (80, 150 and 200 grit) to be pretty tiresome. I have used OSPHOS solution many times before on another restoration project that supposedly turns rust back into metal, but you really need to knock all the heavy rust off first. I'm thinking there ought to be some type of solution to spray on, let set, power spray off then prime? Sand/media blasting is out as there are NO close operations.
Any ideas or possible solutions would be greatly appreciated.
| | | | | Joined: Sep 2010 Posts: 2,329 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,329 | You may want to try a evaporust type gel .I have used evaporust type removers on parts that you can put in a bucket but I think there is a gel or I heard of putting paper towel over the part and keeping it wet with the product.might be a option before you use the rust encapsulater. | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | Are you using power tools or hand sanding (which would indeed be tiresome - but you'd have some serious guns afterward ;)) to remove the heavy rust? Eastwood has a tool that's supposedly pretty good at removing rust, but I haven't used one. I have used an angle grinder with a flap disk on it, and it has taken me only about an hour to strip an entire front fender. Like Kevinski suggested, Evaporust is a good product. Use a towel to keep it wet so it can work. I've tried their gel product but with so-so results.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2005 Posts: 4,259 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,259 | Try a DA with 40-60 grit, followed by 120 grit. That'll leave a great surface for epoxy primer to grab on to and leave the primered finish looking smooth. | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | I have one of those Eastwood Contour stripping tools and they do work great. However, if there any deeper rust pock marks, it will not remove them. On those, I used a stiff wire wheel mounted on an angle grinder, then followed it up with epoxy. Evaporust would be an option also.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: May 2015 Posts: 11,134 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,134 | No sander will get pits cleaned out. A wire wheel does better, but even that's not 100%. Sandblasting is the only real way to clean out pits completely.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,502 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,502 | On my deepest pits, I have a hand held sand blaster that I used to take care of that. Fortunately there were only a few areas.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | The real question is, how long do you want this paint job to last? Rust on flat surfaces can be addressed by sanding, but what a about the seams where adjoining panels meet? You can't get in there with sandpaper and using chemicals in these seams will leave residual nastiness that will come back to haunt you even with epoxy primer on top of it. Sandblasting is the best solution for removing rust so that epoxy primer can do its job.
