Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 136 guests, and 3 robots.
Topics128,281
Posts1,058,465
Members48,490
#1591249 11/04/2025 4:14 PM
Hey I wanted to see if anyone could get me a pic of the SM420 mounted in place from the engine side how it sits on the frame.
Thanks in advance.
Treyz #1591251 11/04/2025 4:55 PM
If you'd settle for an SM420 in a 3/4 ton GMC here is a picture. I assume Chevy's are the same. But mine doesn't "sit" on the frame. The mount at the front of the engine and the 2 mounts on the bellhousing are the only mounting points for the engine/SM420 package. The only "mounting bolts" for the SM-420 are the 4 bolts that hold the transmission to the bellhousing.
That is perfect. I needed to see how close the trans sits down on the cross support. Mine is also a 3/4 ton GMC. Perfect.
Thanks Bill
Treyz #1591253 11/04/2025 5:13 PM
U
U Offline
Maybe a good time to ask, but I'm wondering if my 4-speed transmission in my '46 is a SM420? If so, I can try to get some pictures of it mounted for you.
~ John in Utah
Here We Go
Follow in his DITY Bay
UtahYork #1591265 11/04/2025 8:55 PM
John - Your pictured 4 speed w/main case casting number 590474 is the SM420 predecessor - GKT-134, otherwise affectionately known as a "crashbox". smile It's a non-synchronized 4 speed with straight cut gears where the SM420 2nd through 4th gears are synchronized and have helically cut gears (1st and reverse are un-syncrhonized straight spur gears).
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1591287 11/04/2025 11:32 PM
U
U Offline
Originally Posted by Gdads51
John - Your pictured 4 speed w/main case casting number 590474 is the SM420 predecessor - GKT-134, otherwise affectionately known as a "crashbox". smile It's a non-synchronized 4 speed with straight cut gears where the SM420 2nd through 4th gears are synchronized and have helically cut gears (1st and reverse are un-synchronized straight spur gears).
Thanks Dan! I heard it was a "crashbox", but I didn't know the official name. I'm guessing my pictures would not help.
~ John in Utah
Here We Go
