0 members (),
106
0
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | What I need is a 7/8 x 16 thread chasing die. The only one I found from a Portland tool shop was over $60! There have to be adequate and less expensive chasing dies out there. I've tried lots of places and they all say 7/8 x 14 nf is all they carry. Any suggestions appreciated and if you have one laying about your shop you haven't used in years I would gladly purchase it or 'rent and return'
Background: I'm putting new seals in a first series 10-bolt open driveline rear end and find the PO really buggered up the end of the pinion gear shaft. The nut was extremely hard to get off all the way out. I'm ready to put it back together and got a new 7/8 x 16 nut but can't get it started due to beat up condition on end of shaft.
I tried a thread file but it doesn't do the job. Thanks again for any help, Jerry | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | jbinwa,
That is a weird TPI. I have seen external thread restorers that have dies for the TPI but they are $92.00 clams.
The thread file will clean out dirty threads and can straighten out slightly bashed threads, but for the most part they don't work well.
Your pinion shaft is tough material, and as you noted, was abused by a previous 'wrench'!
My suggestion would be to taper the immediate end of the shaft with a small air grinder or angle head grinder. Get rid of the ' mushroom ' on the end and you will get back to good threads.
You can use a small file (not a thread file) to clean up any threads on the end that are deformed. It's possible to use a nut as a 'faux' die if you put some Neverseize on it and run it over the damaged area a few times.
The issue doesn't appear to be bad threads but a mushroomed end on the pinion shaft. Good luck.
Stuart | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | You need a 7/8 x 16 NS or National Special. McMaster comes in at $71, so that is a bust!
Like Stuart says, a grinder usually works for me! | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | A small 3-cornered file is what you need, use it to dress the threads up. It has always worked for me. Brian | | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | Thanks to each of you for the tips/suggestions. I finally got the nut started by using a sanding wheel on the 4 in. grinder to bevel the end of the pinion shaft back into the good threads and then a thread file to bring up the tip of the threads that were flattened and finally a 3 corner file to dress up the 'entry ramp' thread. The pinion shaft is hard material as Stuart noted. The new nut was the right self-locking type that is punched to give the threads a not-quite-round profile so it won't back off. Thanks again for the help, Jerry | | | | | Joined: Jan 2007 Posts: 27 Junior Member | | Junior Member Joined: Jan 2007 Posts: 27 | Try MSC Direct,They will send you a FREE catalog with every tool in it just about. The prices are fare,the tools are A+ The catalog is like 5 inchs thick,and the shipping is FAST! Wick
Every Hour you spend Fishing adds A Day to your Life!
