2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1590056 10/20/2025 6:19 PM
What's the best and easy way to know if your front leaf springs are good?
When we jack-up the front end the left wheel leaves the ground about 1 ½ inches after the right side does.
Obviously that demonstrates uneven wear so they should both be replaced, along with the shackles and bushings.
1950 Chevrolet 3100 (Ol' Roy)
That you may need springs is likely but Help me understand… how are you jacking the front up?
If by the center of the beam axel it tells nothing as springs stay compressed?
1st-on level ground is the truck level side to side?
2nd-what is the angle of the front shackle in relation to frame ( sagging spring get longer and shackle rotates away)
3rd- what condition are the shackles, spring eye bushings and frame pivot bushing’s and pins
4- Check the FAM on spring dimensions and compare, might have ride height numbers too
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
If you're jacking from the center of the front axle, it says more about the condition of the rear springs than the front.
Like Chuck said, take some measurements and compare with stock dimensions.
That being said, if they're original springs, they're likely shot and you'd do yourself a favor by replacing all 4 springs.
I'll have to do more
However, 1- yes the ground is level; 2- the shackles rotate forward; 3- unknown; 4- will need to check FAM
for your information we always lift the truck by the center of the front I Beam; and the rear by the center of the differential
If you lift by the axle, unless the jack is perfectly centered, one wheel will come off the ground first, depending on how far to one side the jack is.
The only real way to check the springs and associated stuff is to jack from the frame or bumper and let the axles drop and the springs relax.
Got it. Just yesterday I was looking at the I Beam and related parts and I concluded that the way we were jacking the truck up wouldn’t allow for the springs to drop and give us a realistic view of how much the springs dropped to get a good drop measurement. Thanks for suggestions.
ASAP I’ll pass results.
