5 members (WICruiser, GMCJammer51, Southerntruck, Phak1, NorCal52Suburban), 73 guests, and 1 robot.
Topics128,196
Posts1,057,395
Members48,471
Page 3 of 6 1 2 3 4 5 6
August 2021
Kind of a slow month (must have been fishing wink ). Painted the back grille bars with Rustoleum Canvas White. Pulled the fuel pump and cleaned it up. Found a part number on it and ordered a repair kit from Then and Now Automotive.
Rear grille bars painted Canvas White
Fuel pump repair
Fuel pump part number
September 2021
Set up my garage extension (a Shelter Logic tent) for painting. After replacing a few gaskets and seals on the engine, painted it with the blue-grey paint from Jim Carter. It matched the remnants of paint on the engine pretty closely.
The painting tent
Engine painted
Valve Cover painted
November 2021 (what happened in October? Apparently nothing.)
Hibernation - Chassis covered in snow. Coated exhaust manifold with Calyx. Assembled front engine mount.
Snow covered chassis
Exhaust manifold with Calyx coating
Front engine mount
U
U Offline
It's been fun to read and see these progress reports. There are some times I feel I've done nothing on my truck and these pictures help motivate me to keep going.
~ John in Utah
Here We Go
Follow in his DITY Bay
December 2021
Attempted to match the blue-green paint on the heater housing, but failed miserably. Decided to go with the “standard” Rustoleum Hammered Bronze. Took a trailer tongue jack that had given up and turned it into an engine hoist leveler. It mounts on the engine using the two valve cover studs. Hoisted the engine off the stand and installed the bell housing, flywheel and clutch. Cleaned and painted rear engine mounts. Rebuilt the generator and starter. Discovered that the generator was a Western Auto rebuild as it had “WIZARD” stamped on the housing. It got new bearings and brushes and a test run as a motor to check it out. The starter got the same treatment and a coat of paint.
Paint match attempt on heater
Paint match attempt 2
Engine Leveler fabbed from failed trailer tongue jack
Engine Leveler in position (valve cover removed for actual use)
Engine on hoist
Painted rear engine mounts
Western Auto brand stamp on generator
Generator rebuilt and in vice for testing
Starter rebuilt and painted
January 2022
Mounted the transmission on the engine stand and opened it up for inspection. The only real issue was a shift collar that was worn a bit. I built it up with weld and had a friend machine it back to spec. Installed new shift shaft seals. Painted it and mounted it to the engine on the cart. Disassembled the steering gear (found some wood slivers inside.) Cleaned it up completely and rebuilt it.
Transmission on engine stand for inspection and cleanup
Input shaft and side cover removed for inspection
Worn 2-3 shift fork
Shift shaft seals replaced
Weld buildup on shift fork
Transmission reassembled and painted with cast iron paint
Transmission bolted to bell housing
Disassembling steering gear
Steering gear reassembly
Steering gear painted
January 2022 continued
Rebuilt the wing vent windows. Jay Kassis’ videos Part 1 and Part 2 were very helpful. Got the rivets and other parts from the Filling Station. Stamped numbers on the starter data plate and installed it on the starter and mounted the starter to the engine.
Vent window rebuilding
Vent window rebuild 2
Replacement Starter data plate
Starter mounted to engine
February 2022
Worked on reupholstering the seat. The frame needed a little repair and painting. Used a kit from Jim Carter in the original maroon color. Dug out the remote oil filter and cleaned and painted it. This is an S-2 style that holds 2 quarts. Rebuild the door hinges with oversize pins and bushings, which should keep the pins from seizing up in the hinge bars which they're prone to do. Replaced window regulator rollers and rivets.
Stripping the old upholstery off- damaged areas circled
Seat springs repaired and painted
Brushing the batting off the jute
Installing cover on seat bottom
Completed seat bottom
OIl Canister
Oil canister cleanup
Filter Canister painted. Federal Safety Blue and Rustoleum Orange cap
Rebuilt door hinges
Closeup of flanged bronze pin bushings
February 2022 continued.
Picture of window regulator roller riveting.
March 2022
Got interior paint lightened up at a local paint shop. What I got from Jim Carter (spot on the right) was way too dark compared to the unfaded paint on the speaker grille. The spot on the left was what they could do, and I settled for that. Worked on cleaning up small dings and patch panel weld joints on the cab.
Speaker grille with original paint and test spots
Filling small dings on the back of the cab
Finishing cowl joints
U
U Offline
The upholstery job on the seat looks great! I didn't know Jim Carter had a kit, but will check it out. I'm liking the colors on the oil filter housing. Just a few stickers and it will look brand new. Excellent work Kevin!
~ John in Utah
Here We Go
Funny you should mention stickers. grin Stay tuned. Coming soon.
Good job on both the seat and oil filter .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
April 2022
Worked on fixing the oil canning on the roof without much success. More on that later. Printed a decal for the oil filter canister lid. Vendors offer decals for the S-6 oil filters, but not for the S-2. So I did a little modification of a screen capture and made my own. Some decal material and color laser printing at the local UPS store did the trick. I may have a couple left.
Roof is a little wrinkely
Oil filter decal
Oil filter decal in place on lid
Here's the S-6 decal I used as a basis for my S-2 decal
May 2022
Installed stick-on sound deadening material in the doors. Nearly got my arm stuck inside. Installed the doors on the cab for test fitting and adjustment. Driver door was a little tweaked, so tried tweaking the cab to compensate, but it wasn’t going to move. But I managed got the door fit pretty close. Passenger side door opening turned out to be messed up (moral of the story is measure, measure, measure before welding) so had to trim the door edges a bit for a decent fit. Straightened upper door panel edging and painted them. Rustoleum brown was a decent match to the color of the repop panels.
Sound deadening material for doors and cab
Arm's a little raw after extraction from the door. OW!
Hung the doors from engine lift arm to install
Driver door fit at rear
Driver door fit at top
Setup for attempted cab tweak - it's not moving
Driver door front gap - close enough
Passenger door gap at top - too close
Passenger door gaps - too tight at lower rear and upper front
Upper door panels ready to install
June 2022
Trimmed and welded the passenger door edges. Worked on roof oil can fixing Video link. Robert McCartney (MPandC) was nice enough to advise me via facetime call on the proper shrinking procedure to take care of that. He showed me where to shrink the metal to get it back into shape and suggested how to raise the roof overall. Thanks Robert!
Trimming the upper edge of the passenger door
Trimming and welding the back edge of the passenger door
Checking for low spots in the roof
More low spot checking
Marking areas that need shrinking
Raising the roof
Using a slapper on the high spots
July 2022
Not much done this month (more fishing?) Hey, it's summer in Alaska.
U
U Offline
I was noticing the captions added to your pictures and figured out how I can do that too. I'm going to start adding those to my pictures.
~ John in Utah
Here We Go
W Online: Content
Kevin, I am curious which version of Siless sound deading material you used. I am anticipating adding sound deading material to my doors and cab and exploring different options for materials.
1949/50 3600 Project
Follow in Project Journals
I used the black foam stuff without any foil. Got it from Amazon. I did the roof and behind the gas tank with it as well, and had plenty left over.
August 2022
Worked on assembling the bed. Got the front panel bolted in as well as welding and re-primering on the rear cross-sill. Test fitted the outer boards in place and drilled the holes to match the angle strips. Stored the partly assembled bed on the chassis. Put the first coat of stain on the bed wood, Brushed on and took forever to dry. Pics show what I used for stain.
Bed sides ready to assemble
Bed assembled and outer boards fitted
Bed in storage on chassis
Black stain on bed wood - first coat
Stain used on bed wood
Stain - back of can
September 2022
Painted bed strips, running boards and rear fender support brackets. Painted interior trim pieces with ALK-200 that I got lightened. Lays down nicely and looks good. Painted the inside of the doors (second pic is a little off-color from lighting.) Painted the seat frame. Worked out some small dents on dash trim and glove box door and polished them using a felt wheel on a dremel too and drill motor.
Painting bed strips and running boards
Interior trim painting
Painted interior of door
Seat frame painted
Polishing speaker grille trim
Speaker trim polished
Glovebox door before polishing
Glovebox door after polishing
October 2022
Storing painted parts in my trailer, Cleaned up the firewall pad and painted it. Sandblasted and primered the speaker grille, then painted it and the center panel on the glove box door. Drilled out the top cowl vent pivots on the cab to fit the new shoulder rivets for it. Pic of rivets for anyone who needs the info to repair their cowl vent
Speaker grille painted
Painted glove box door
Shoulder rivets for cowl vent pivots
November 2022
Took the month off. Please don't call me lazy. wink
December 2022
While visiting my daughter and son-in-law in Juneau, used his ultrasonic cleaner on the Carter YF 964S carburetor and rebuilt it with a kit from carbking. (Carb pics are pre-rebuild.) Started working on a frame for my old tailgate for a wall-hanger.
Carter YF 964S carb
Carter YF 964S carb
Tailgate wall hanging project
January 2023
Worked on the rear fenders removing dents from tire chains slapping the underside. Pics later.
February 2023
Built a painting stand for the rear fenders. More bodywork on them. Chassis buried in snow. Good thing I took my painting tent down, as it likely would have collapsed with this snowfall.
Painting stand for rear fenders
Snow piled on chassis
March 2023
Still more bodywork on the rear fenders. Got to the block sanding stage. Pics later.
April 2023
Still straightening rear fenders. Installing the doublers where the running boards bolt to the fenders. Riveted the fender crown braces on the fenders. Pic of some of the tools used . A PVC pipe coupling serving as a donut dolly with a crowned hammer for shrinking, and a baseball as backup for use with a pick hammer for the tire chain.dings.
Doubler used to locate spot welds - cleaned paint off for spot welding
Doubler inside fender
Paint removed for spot welding
Spot welded in place
Doubler spot welded
Lumpy fender - loose tire chains
Rivets for fender brace clinched
Fender brace
Dent removal tools
May 2023
STILL block sanding and filling rear fenders. frown Set up the tent in front of the garage (took it down for winter to avoid having to clear snow off it.) Installed rivets for cowl vent pivot points. Another primer coat on rear fenders. Spot putty on front fenders. Completed frame for tailgate wall hanging.
Another lumpy fender
Block sanding
Cowl vent pivot riveted
Spot filler on rear fenders
Fenders in primer
Front fender with spot putty
May 2023 (continued)
Undercoated front rear fenders (ignore that incorrect photo caption blush.) Last primer coat on fenders. First color coat of paint on fenders. OMAHA ORANGE BABY!! yahoo
Front fender undercoatingi
Fenders in final primer coat
Fenders in color
Rear fenders in Omaha Orange
AD Addict & Tinkerer
P Online: Content
What did you use for the undercoat?
Phil
Project Journals
Stovebolt Gallery Forum
Undercoat used was rattle can stuff from the local parts store. I think Upol brand. I put on a couple coats. Epoxy primer was underneath after sandblasting.
P Online: Content
I want to do some type of undercoat but haven't decided yet. I saw that you did the undercoating before you painted and I wasn’t even thinking about the sequencing but I won’t get to the fenders until next year. Thanks!
Phil
Project Journals
Some have used bed liner for the fenders to help with the rocks being thrown up .
"The Journey"
Follow in the DITY
I thought about using bedliner, but I'm a cheapskate. My running boards have bedliner top and bottom so that's covered (Heh!) I didn't expect them to do the bottoms, but it's all good.
Phil, I undercoated the cab and fenders before painting so I didn't have to worry about masking when spraying undercoating after paint.
June 2023
Final color coat on fenders. Sanded and spot primered bed. Primered bumper splash apron, hood center strip and gas tank filler. Straightening outer grille bars and spot filling pits. Final primer on bed, grille bars and bumper apron. Shot color on bed, tailgate, grille bars, running board splash aprons and cowl vent. Installed bed wood and strips.
Spot putty on bed
Patching grille bars
Bed in Omaha Orange
Omaha Orange on grille bars & running board aprons
Bed wood and strips installed
July 2013
Sanding bumper splash apron and hood center strip. Block sanding hood and fitting center strip. (no pics)
August 2013
Sanding and bumping dents on hood. Used 3M Noise Vibration and Harshness material between hood support and hood skin to prevent flutter. Factory had padding between there, which was AWOL. Put NVH material between cab stretchers and rear skin of cab. Primered hood and bumper splash apron. Filling and sanding cab roof and cab back. Filling and sanding cowl weld joints. Drilled cowl for right side mirror bracket. Cleaned up cab and shot final(?) primer coat. Grinding welds and drilling holes for seat belt mounting. Prepped, primered and painted cab interior.
NVH material under hood reinforcement
Spacers for NVH material under hood reinforcement.
Final filling and sanding on cab roof
Last primer coat on hood
Final primer on cab
Final primer on cab
Interior paint on dash & cab interior
September 2013
Masked cab for exterior paint and shot color on the cab. Masked, prepped, and shot color on doors and bumper splash apron. Sanded hood and shot color on hood. Installed sound deadening material on cab roof and rear. Shot a second coat of color on tailgate and running board aprons. Prepped and painted steering column, steering wheel and shifter. Installed the gas tank and filler. Assembled grille.
Masking cab
Shooting color on cab
Final paint on cab
Back of cab in final paint
Masking doors for exterior paint
Doors and bumper splash apron painted
Final color on hood
Steering wheel painted also turn signal switch
Assembling grille back bars
Completed grille assembly
Moderated by  Phak1
