5 members (Otto Skorzeny, Samantha, Hotrod Lincoln, Ricks Big Dump, Hanks custodian), 164 guests, and 1 robot.
Topics128,081
Posts1,056,073
Members48,434
#1589723 10/15/2025 4:55 PM
H Online: Content
I just acquired another toy for the shop- - - - -a 3 phase variable speed motor drill press with a little over 10 inches from the spindle center to the column, a 4 1/2" diameter column, and a heavy cast iron table that measures 18 X 20 inches with T slots for hold-down clamps. It's also got a built-in coolant reservoir in the base, and a mounting hole for a recirculating pump. The thing stands just a bit over 6 feet tall, and weighs several hundred pounds. The table goes up and down on a rack & pinion gear, and swivels 360 degrees to expose a floor pedestal that also has T slots in it. With the table in the fully lowered position, it looks like there's going to be room to stand a stovebolt engine block on end under the spindle. Of course, it's not nearly as big as the radial drill press I acquired some time ago. That one's got a 9" diameter column and a power head that travels nearly 4 feet in and out from the column. I believe I've got all the hole drilling chores I can think of covered with those two machines! One more reason to finish wiring up my shop for the 3 phase rotary converter Coilover practically gave me some time ago!
1 Offline
Sounds like a high-quality commercial grade tool.
H Online: Content
Definitely- - - - -an industrial grade hole shooter! "Go big or go home!"
Moderator
Moderator
2 Offline
What company built it and what is the RPM range?
All the drill presses sold in big box stores are set up for woodwork.
Hard to find any with lower RPM's for metal work.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
H Online: Content
It's a Wilton 20" press about 50 years old, one that came out of the maintenance department of a factory that closed down several years ago. It has a Morse taper spindle with a 6" vertical stroke. The speed chart on the control panel shows a minimum speed a little over 60 RPM. It's also reversible, like most 3 phase machines. I found it about 40 miles from my place on Facebook Marketplace. It weighs around a thousand pounds, so it's definitely not a hobby machine! Pics will get posted once the forum gets over being constipated!
H Online: Content
Lousy lighting- - - - -just about dark.
Moderator
Moderator
2 Offline
Looks good Jerry and I like that rpm range. It just needs to be cleaned up and it will work for you.
Don
"The Flag Pole"
1953 1-ton pickup
Looks like a serious machine for some serious stovebolt work.
RonR
RonR
1970 340 Duster
1964 CJ5
H Online: Content
Once I fabricate a few setup fixtures, I'll use it to drive my line bore tool when I convert stovebolt blocks to use small block 400 V8 main bearings.
Drill press is the ONE tool I won't get rid of, out in my shop. It has earned it's keep many times over. Jerry, I assume it is belt driven and if so, don't wait til a belt snaps. Get a couple extras now.
Craig
Looks real nice and sturdy.
Back in the day working on big mills etc. I would call a Bridgeport a glorified drill press. But really a very universal machine, I like them now, just can't do big cuts.
Moderated by  MNSmith
