4 members (Charles in CA, Otto Skorzeny, 2 invisible), 107 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
I loosened my main caps in preparation of dropping the crank to install new rear main seal. Took off the front cap to make it easier to remove the old oil pan gaskets in the corner where it meets the cap.
There is an old paper gasket, or shim on the cap where it meets the front plate. Or maybe just used for protection during assembly?? Also, there appears to have been some sort of black sealant, or something??, possibly to keep oil from getting between the oil pan gasket and the front plate and leaking out?
Do I need to add sealant to the main cap? Just leave the old paper "gasket" in place, or is there a replacement for it? I haven't seen any kind of replacement.
Engine is a '59 235. See attached pic.
Thanks!
Ron
P.S., might as well also ask here...do you guys use sealant on the timer cover, or just the gasket?
Looking at it again, perhaps it's half the timing plate cover gasket that got stuck to the cap, split in half, and came off with it?
You might be able to get by with some RTV sealant between the front cap and the front engine plate, but there does need to be something in there. Oil could seep out from the front of the front main bearing or out of the timing cover. The "right" way would be to remove the timing cover and front engine plate, and replace the gaskets and the front crank seal. Depends on whether your front crank seal is needing replacement too.
Now thinking maybe someone had a leak and tried to remedy it by cutting the bottom half off a second front plate gasket and putting it between the cap and plate. The plate gasket doesn't look like it peeled in half.
Looks like you already have the balancer and timing cover off. You’d need to pull the cam out to get the plate off, but might just be a good time to replace the gasket. Stick the gasket and front plate on after you have the bearing cap in place.
Well, while I'm at it, maybe just get a little bigger cam too... grin
Rather than hassle with replacing the gasket, I'd use a brush-on sealer like Copper Coat or Permatex Super 300 between the main cap and the old gasket. You're more likely to cause more leaks the further you tear things apart, and I doubt that the rear timing plate gasket can be found anywhere other than in a full overhaul gasket set.
I believe the rear timing plate gasket comes with a timing cover kit. I've got extras. Yep, here's Fel-Pro's offering (pic). But like Jerry said, it's possible to seal it up without replacing the gasket.
Would you remove the piece of gasket that's stuck to the cap, or put the sealer on top of it?
If it wasn't leaking before, I believe I'd leave everything "as is", and just add a little sealer.
Yes, and very good advice. RTV has no place on any 1950's or 1960's, truck engines or what ever else.
