2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,335 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,335 | I had put in a 3.55 gear set and had a fellow set the gears for me and while I was doing my bed wood I noticed a drip from the bottom pinion bearing retaining screw. At a closer look I noticed the 3 screws were not screwed in evenly. I was able to screw the bolts to even them out and thought that would solve the leak as the bottom bolt was the one that was not in as far as the other two. I am thinking that I can loosen the lock nut and put some thread tape around it and tighten it back up. I was planing to dump the oil and check the gear gear pattern and the rear bearing clearance to be sure nothing got moved. Any one else experienced any thing like this? Thanks, Kevin
| | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | If you're talking about the pinion bearing screws, I loosened the lock nut and the pins just a bit and put some non hardening gasket sealer on the threads. I haven't noticed a leak there since doing that, although I've only put 100 miles on it. No worries about losing the gear pattern, unless your guy didn't get the bearing seated in the first place. That's not likely if two of the pins were tight. I would seal the threads, tighten the screws and move on.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2010 Posts: 2,335 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,335 | Thank you. Yes the pinion bearing screw at the bottom was sticking out farther than the other two but everything was tight. I did have another rear axle to look at and to check the depth and they are in place enough to hold everything in place but was unsure about messing with them. Do you remember what sealer you used I was thinking maybe aviation gasket by permatex. Thank you Kevin | | | | | Joined: May 2015 Posts: 11,176 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,176 | I use a generic sealer. I got it at my local parts store. Don't remember the brand, but very similar to Permatex #2. You'll probably want something with a little thickness to it so it squishes into the threads as you tighten the lock nut. I think aviation sealer might be too thin.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Does that truck have an open driveshaft rear axle?
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Try Permatex Gel Gasket. It goes on as a thick liquid and cures to form a leakproof seal. HMMMM-- - - - -looks like it's got a new name! www.amazon.com/Permatex-51813-Anaerobic-Gasket-MakerJerry
| | | | | Joined: Sep 2010 Posts: 2,335 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,335 | Closed driveshaft ,Thanks I think I have some of the51813 permatex I will give it a try | | |
