1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#1589235 10/08/2025 4:23 PM
I currently have a 12v ……. 235 with points/coil etc (no upgrades). As I’m rewiring to fix the previous owners rats nest, I noticed that there is no ballast resistor on the fire wall. Doesn’t it require a ballast resistor so I don’t burn up the points? I’ve been driving it around town for about a year now. In the future, I plan to upgrade to HEI, I just don't have the funds to do it today.
Thoughts?
Chris
Yes. You need one. 6v don't.
1950 Chevrolet 3100 (Ol' Roy)
Thanks Otto! I can’t believe I didn’t burn up my points already! I’ll do a temp install until I put my HEI on her.
Maybe your coil is marked "12v" or "No resistor required"? Some aftermarket coils have a built in resistor. Like this one. Down side is that the coil doesn't produce a full spark while starting the engine.
Morning Bill! I’ll take a look at it today when I’m playing with the wiring.
H Online: Content
If your multimeter has a "DC amps" function, you can measure primary current in the "engine not running/switch on/points closed" mode. Most points can handle a maximum of 5 amps without damage, but "less is better" as long as the engine starts and runs reliably.
Hotrod, I have a ballast resistor at the house, I think I’ll just throw it on until I get to the point of upgrading to HEI.
ndkid275 #1589355 10/09/2025 11:03 PM
Unhook both small wires from the coil. Measure ohms from one coil terminal to the other. Anything over 3.5 ohms (a guess by me, maybe 3.0 ohms) probably has a built in ballast resistor.
What part numbers and manufacturer name are on the coil?
By the way, does your starter have support to bypass the ballast resistor for easier starts?
Quasi-related question:
When a ballast resistor fails, how does it typically fail?
Is it just a total loss of continuity? Excessive resistance? Too little resistance?
1951 3100
H Online: Content
The most common failure is an open circuit- - - -no current flow. A ballast resistor is just a coil of nickel/chrome wire, usually mounted in a ceramic heat isolator.
Bill,
It’s a key start, not a stomp starter.
So your starter solenoid will have 3 studs to attach wires.
A big stud for the battery cable.
A small stud (usually marked "S") that comes from the start position on the ignition switch. When activated, it causes the starter solenoid to pull in, engaging the starter drive gear to the flywheel and at the same time supplying power to cause the starter motor to spin.
Another small stud (usually marked "R") which passes battery voltage down the attached wire directly to the + terminal on the coil. This "bypasses" the external ballast resistor, supplying full battery voltage to coil + while starting the engine.
But before doing anything you need to find out if your coil has an internal resistor.
ndkid275 #1589438 10/11/2025 11:49 AM
AD Addict & Tinkerer
As Bill pointed out earlier, most coils are marked if they have a built in resistor. I would do a thorough examination.
Phil
Project Journals
Stovebolt Gallery Forum
