0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2023 Posts: 7 'Bolter | | 'Bolter Joined: Aug 2023 Posts: 7 | I redid my front brakes never saw a setup like this before so I videoed it. Got new wheel cylinders, relined shoes, and turned drums. I noticed putting it together that the brake shoes seamed to be sitting in just slightly (less then 1/16") from the cylinder rods, but it all worked. I adjusted the shoes so they only rubbed the drum about an 1/8 of a full turn. About 100 miles later (over three months) I was feeling a pull to the right. When I jacked up the truck I found that I could not turn the wheel without a lot of force. I had a broken spring, replaced it reassembled and wheel turned fine. Pumped the brake a few times and the wheel would not turn again. pulled it all apart, as I moved the drum out, suddenly I could turn the drum. When I got it apart the cylinder cap, which seams to float on the unit, was kind of angled seemed to go back okay, but the other end of the cylinder was not doing that. Because the shoes are attached to a frame bolted to the backing plate do they sometimes need to be shimmed out? I'm guessing the cylinder cap was binding and got stuck but I don't know. I pulled the cylinder and it looks good. I looked at my video and everything was together the way it was when I first took it apart.
LorenO 1952 Truck
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Having trouble understanding your issue from your description. If you have a place to host your video, you can post a link to that which may help us understand. Brakes that don't release can often be traced to a deteriorated brake hose that acts like a check valve and doesn't let the fluid out of the wheel cylinder.
I'll move your thread over to Driveline where it'll be more on topic.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
