1 members (moparguy), 113 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#1589099 10/06/2025 3:53 PM
I have more zippers then a pair of cargo pants
This is what I have been getting when trying to post a question or make a reply….joe
And even got the same fatal error code when I went to make this post.
Fatal error: Uncaught TypeError: in_array(): Argument #2 ($haystack) must be of type array, false given in /var/www/html/ubbthreads/libs/user.inc.php:608 Stack trace: #0 /var/www/html/ubbthreads/libs/user.inc.php(608): in_array() #1 /var/www/html/ubbthreads/scripts/addpost.inc.php(668): user->check_group_join() #2 /var/www/html/ubbthreads/ubbthreads.php(286): page_addpost_run() #3 {main} thrown in /var/www/html/ubbthreads/libs/user.inc.php on line 608
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
That's been an ongoing problem for maybe 6-8 months. The post actually works, but you get that message popped up. If you go back to the site and click on Active Threads, your post should be right on top of the list.
It's mainly an annoyance. The software people at UBBThreads have been notified about it, but as usual, they're agonizingly slow in addressing issues. frown
thumbs_up thumbs_up thumbs_up thumbs_up thumbs_up thumbs_up
~ Joe
AD Addict & Tinkerer
I’ve been getting the same fatal error for the last week. I’ll go in and clear out my cookies and it works for a day or two, then get another error.
Phil
Project Journals
Stovebolt Gallery Forum
Insomniac
Insomniac
If you get this error, it's not your fault! This is a programming error and it should have been fixed by now. The programmers must have higher priority problems to work on or it's buried deep in the code. The error seems random which makes it hard to trace and correct.
Reminds me of the old days. I would get to work and the System Admin would be waiting for me with a 2" thick system dump print out. I would have to go through it to figure out what went wrong. It would end up being something simple like a user had entered an I (capital i) instead of a 1 (one) in a data entry field. Database wants a number and it gets a letter; bad! That's a type mismatch (TypeError). Anyhow, all you had to do was ask the programmer to add a couple of lines of code to check for it and it won't happen again.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
It also doesn't help that we are getting inundated by very high "Guest" counts again. This morning we are hitting over 1300 "Guests On Line" again. I found just getting into the site and logging in took more than the usual time frame (about 30-50 seconds for each step).
I haven't looked at location info for these guests yet this morning, but looking randomly yesterday, when the guest counts were 800-900 or so, showed more than a 50% average of them being from non-US based IP locations. A lot of them showing from Brazil, Vietnam, and odd/unusual locations scattered throughout the middle east and the European far east. headscratch
As of this posting, count now shows 1,423 Guests On Line
~ Dan
1951 Chevy 3 window 3100
Authorized Pest
Authorized Pest
I just got the fatal error. First time today or in a long while ... like week maybe. frown
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
TooMany2count #1590588 10/27/2025 11:11 PM
Authorized Pest
Authorized Pest
I got the fatal error three times this afternoon when replying a post. I didn't happen when I started a post. frown
~ Peggy M
1949 Chevrolet 3804
TooMany2count #1590589 10/27/2025 11:11 PM
Authorized Pest
Authorized Pest
Ha, it just happened when replying here. I kept trying and each time, I got the fatal error.
Boooooooooooooooo.
~ Peggy M
1949 Chevrolet 3804
klhansen #1590621 10/28/2025 12:56 PM
Donald S.
Donald S.
Yes, I get it too every time I post!
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Beginning to End Slideshow
More images in Flickr
\|/\|/ Dual Ex. \|/\|/Dynamat
Please don't tell my wife how much this thing cost!
If you click on your username (top right) then click on cookies, then click expire cookies, you will stop getting fatal errors every time. You’ll have to re login but it sill clear the error for a while. It most likely will return after a few days but at least you not getting it every time.
Phil
Project Journals
Phak1 #1590632 10/28/2025 5:12 PM
Donald S.
Donald S.
Phak1, thanks for the info!🤔
1953 Chevy 5-window
Southerntruck #1590680 10/28/2025 10:47 PM
thumbs_up
Phil
Project Journals
TooMany2count #1592636 11/23/2025 11:35 PM
Authorized Pest
Authorized Pest
I'm getting the fatal error message again. I know Paul has his hands full and Dan is helping him with other issues.
~ Peggy M
1949 Chevrolet 3804
TooMany2count #1593749 12/08/2025 12:29 AM
I've found a quick way to bypass the error message- - - -
When it appears, click on the "back" arrow at the upper left of the page. The post you typed will reappear. Right click and hit "refresh". The post will appear, but you're not done yet. Click on "edit" and post without changing anything. Now your post will appear in the proper order. This has been working for me for several months.
TooMany2count #1593751 12/08/2025 12:30 AM
Authorized Pest
Authorized Pest
I've been getting it again ever since last night.
I end up going back to the beginning since SB is bookmarked. Annoying but at least I see it's there. frown
I got it when posting this and a note to a PM.
~ Peggy M
1949 Chevrolet 3804
Peggy M #1593790 12/08/2025 8:16 PM
I get it a lot especially in the last week all of my replies have had it ,Like Jerry says I just hit the edit button and it will usually put the reply in last reply que on the main menu. Like it happened posting this.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Clear your cookies on this site, and it will not happen as often.
Phil
Project Journals
Cleared cookies and pushing post reply let’s see if it wmorks
"The Journey"
Follow in the DITY
Thanks Phil that seemed to work.
"The Journey"
Follow in the DITY
back yard wrench turner
Today, when I receive an email for a watched thread, I'm getting the fatal error message when I click on it.
Fatal error: Uncaught mysqli_sql_exception: Duplicate entry '211608' for key 'sbf_TOPIC_VIEWS.PRIMARY' in /var/www/html/ubbthreads/libs/mysqli.inc.php:209 Stack trace: #0 /var/www/html/ubbthreads/libs/mysqli.inc.php(209): mysqli_query() #1 /var/www/html/ubbthreads/libs/mysqli.inc.php(138): sql->do_query() #2 /var/www/html/ubbthreads/scripts/showflat.inc.php(449): sql->do_placeholder_query() #3 /var/www/html/ubbthreads/ubbthreads.php(290): page_showflat_run() #4 {main} thrown in /var/www/html/ubbthreads/libs/mysqli.inc.php on line 209
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I just got the same (or very similar) response when trying to open threads on "Active Threads". I was going to report it and when I went to Active Threads again to copy the message, I got through to the thread without getting the message again, even though it had happened a couple of times previously. thinking
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
Same for me with the Rear Main Seal thread in the engine shop.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I was getting a similar error message (didn't think to copy and paste it) when I tried opening a thread. Happened 4 or 5 times, then the thread opened. When I went back to Active Threads and tried another thread, I got the same thing, error 4 or 5 times, then opened. Each time I got the error I used the "go back one page" arrow on the browser page to reset. Using Firefox.
Red dot, center of chest ...
I happened to be working in the forum when it happened and got it fixed pretty quickly.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Paul to the rescue AGAIN! yahoo
Here's another one for you, Paul. Was just checking the Mod Forum and when I clicked on a thread, got the following error message. frown
Fatal error: Uncaught mysqli_sql_exception: Duplicate entry '225015' for key 'sbf_TOPIC_VIEWS.PRIMARY' in /var/www/html/ubbthreads/libs/mysqli.inc.php:209 Stack trace: #0 /var/www/html/ubbthreads/libs/mysqli.inc.php(209): mysqli_query() #1 /var/www/html/ubbthreads/libs/mysqli.inc.php(138): sql->do_query() #2 /var/www/html/ubbthreads/scripts/showflat.inc.php(449): sql->do_placeholder_query() #3 /var/www/html/ubbthreads/ubbthreads.php(290): page_showflat_run() #4 {main} thrown in /var/www/html/ubbthreads/libs/mysqli.inc.php on line 209
Yeah, this is really frustrating.
Paul Schmehl CI 6
geek@stovebolt.com
I think it's fixed. No guarantees.
Paul Schmehl CI 6
geek@stovebolt.com
THANK YOU, PAUL. thumbs_up
TooMany2count #1595278 01/02/2026 10:55 PM
Agreed! Can we ask you what you did to “hopefully” fix the error?
I (we) can’t thank you enough for what you do for this forum!
Phil
Project Journals
Phak1 #1595317 01/03/2026 8:27 AM
OK. I'll admit it. I've been working with Grok to fix some longstanding issues in the software. The last fix we applied caused another issue to rear it's ugly head. Since I had just made a change to the code, I assumed that the change caused the problem and backed it out. (Restored the original code.) But the problem didn't go away. So, I asked Grok what to do, and he found yet another piece of bad code and fixed that. That seems to have resolved it.
Going forward, I'm going to have to set up a test instance of the forum so that I can sort out these problems without blowing up the live forum.
Here's what we've fixed so far:
1) Dramatically increased the responsiveness of the software
2) Fixed the problem with the software sending multiple birthday emails
The problem with random errors when you post is the next one that I'll tackle.
And that should now be fixed. (Fingers crossed.)
Paul Schmehl CI 6
geek@stovebolt.com
Thanks Paul for the update. So far on my end, things have been smooth, responsive and a pleasure interacting with the forum. Great job!
Phil
Project Journals
baldeagle #1595352 01/03/2026 5:55 PM
OH DARN! I guess I'm gonna be lonely in a couple weeks when my birthday rolls around. wink
Agree that things are working very well lately. Thanks again for your efforts, Paul.
Insomniac
Insomniac
You are using Grok to solve software issues? Impressive!
Gord 🇨🇦
Moderated by  baldeagle, Gord&Fran
