1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1589069 10/06/2025 3:44 AM
The generator died on my 261, so I opted to put a 10SI alternator in its place (I havent measured it, but i think the pulley on the alternator is the stock 2 5/8" diameter). The A40/4L420 belt I was using with the generator is too long. Like Murphys law dictates about randomized spare parts, I tried a 4L380 and a 4L400 belt I had in our spare parts shed, and they were too short.
I'm going to the store after work tomorrow to get a 4L410 belt, but I'm a little bit curious - what are the fan belt lengths you guys are running on your 'bolts?
1959 Canadian GMC 9600 with a dump box
Intro / Details in Big Bolts
U
U Online: Content
I have a '60 235 with alternator and I was using a 40" belt. Then I installed a water pump relocation adapter plate which move the WP up and I'm now using a 42.5" belt.
~ John in Utah
Here We Go
Follow in his DITY Bay
Insomniac
Insomniac
1962 235 with stock water pump location and 10si.
Using a Gates 7417 (replaces 11a1055), which is slightly wider (11mm) and longer (1055mm) than the belt in John's pix.
Why Gates renamed the 11a1055 to 7417 seems strange. The 11a1055 number told you exactly what you have.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
