5 members (2-Ton, Jimmie D, klhansen, Hanks custodian, 1 invisible), 109 guests, and 2 robots.
Topics128,166
Posts1,057,012
Members48,458
#1573186 03/22/2025 9:29 PM
Moderated
Moderated
Greetings.
I just acquired a 1958 860 tandem axle truck. loose but not running yet. Couple questions... Where can I get info on this truck? Are there many around anymore? Parts? Thanks for any help!
Big Bolt Forum Moderator
welcome to the site! I am sure some of the guys with the bigger trucks will be along soon and be able to answer some of your questions. What kind of parts are you looking for? I am assuming the 860 is a GMC? You might put a little more info about your truck in your signature. Also, stop by the welcome wagon and introduce yourself
Mike
7
7 Offline
Welcome to the forums agwss, look for a shop manual for your truck, and a factory assembly manual. Also, check out the GM Heritage site, they have "Vehicle Information Kits" that give a boat load of info. A lot of members have Big Bolts and have done major work on them, ask questions and you will get answers.
B Online: Content
Smaller model GMC trucks in 1958 had an ID plate on the left door hinge pillar that had the serial number and engine ID information. I don't know if that carried through to larger trucks like yours. Larger trucks had a similar plate on the inside of the glove box door that had the same info as the tag of the pillar plus additional info about the transmission and rear end.
Below is extracted from the 1955-60 GMC Master Parts Book printed 12/60 and covering 100 series (small pickups) through the largest GMC trucks made during those years . The "S" series letter defines 1958 and 59 models. I have the book in both paper and .PDF form. I don't remember where I got the .PDF file, but if you are interested I could try to find out.
Moderated
Moderated
Thanks for the info. I don't have the truck home yet but I'm sure I'll have questions. Thanks!
Welcome!
Post some pictures when you get it home.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
AD Addict & Tinkerer
In case you don’t know how to post pictures, here’s a link to instructions on how to add pictures to a post.
Phil
Project Journals
Stovebolt Gallery Forum
Moderated
Moderated
Here are a couple pictures. Not sure what I'm going to do yet......
That’s one big rig! thumbs_up Looking forward to more pictures and conversations on your truck. smile
~ Dan
1951 Chevy 3 window 3100
That's a big one! Cool design reminds me of the original Star Trek pilot. Is it a diesel?
Nice !
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Looks like it is pretty complete.
I've got the same style cab on a 61 American LaFrance fire truck, a single rear axle pumper. It's running a 401 V6 engine and a direct drive 5th. gear Clark 5 speed trans. I'm planning to remove the fire bed (rusty and parts missing) and add a commercial 5th. wheel and a gooseneck trailer hitch. The driveshaft mounted fire pump will be replaced by a 3 speed Brownie auxiliary transmission. 15 forward speeds and 3 in reverse!
The 860 was an interesting truck. They used the larger "fat cab" like the 900 series along with part of the hood. They shortened it to meet length laws and used the 550 series grille. I have interchanged parts on these. I butchered a fire truck to make a tractor like I drove over 60 years ago. My 550 came with an Olds engine from the factory rated at 232HP while the 671 in the 860 was only 195HP. 60 years ago 671 Detroits got in my way.
So many of these old, tall rigs remind me of the styling cues found on so many modern trucks today. I think the Nifty Fifties rigs did it better ;-) in terms of styling, at least.
Authorized Pest
Authorized Pest
Concur. Having driven both Billy Marlow's '59 860 and a brand new International Lonestar (the one with the retro front styling) -- Billy's 860 was way more fun but the Lonestar was waaaay more comfy...
smile
JM
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
