| | | Forums66 Topics128,090 Posts1,056,382 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | Howdy, I can't find info on my "59 3100 electric wiper wiring. Where does the power wire hook up? - fuse junction box? If so what amp fuse? - acc on ignition switch? - read somewhere else, someone claiming it hooks to input side of ballast resister?
I would assume for safety.... regardless of position, it needs to be fused.
Greatly appreciate any input. Thank you!! | | | | | Joined: May 2015 Posts: 11,086 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,086 | I would hook up the power wire to either the accessory terminal of the ignition switch or the input side of the ballast resistor (which should be connected to the run terminal of the ignition switch). If you were to connect it to the fuse junction box, it would be powered all the time and the wipers wouldn't stop when you turned off the ignition. But if you have a 3 wire wiper motor, one of the wires should be connected to the fuse junction box so that the park feature works. It needs power all the time to move the wiper to park position when switched off. I can't advise what size fuse you should use. It would depend on the amp draw of the wiper motor, but would likely be 10A or less.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2020 Posts: 1,966 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,966 |
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | Hey Maddoggee1959, just to add more confusion-my stock 1957 2 ton with factory electric wipers is wired to the "ON" side of the ignition switch. This truck has/had no fuses other than the headlight switch fuse. I added a 30 amp breaker to supply a terminal strip.
| | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | | | |
