7 members (mick53, Shaffer's1950, klhansen, TooMany2count, Peggy M, Hotrod Lincoln, 1 invisible), 73 guests, and 2 robots.
Topics128,132
Posts1,056,388
Members48,441
Can HEI, Pertronix, or other electronic ignition operate properly with a DC generator, or doers the vehicle have to be converted to an alternator?
I assume 12v only? No 6v electronic conversions?
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Pertronix sold a 6V electronic ignition at one time, but I don't think they could run fast enough to give me one of their products. I don't see any reason a properly designed electronic ignition system wouldn't function with a DC generator- - - - -all the ignition system sees on the input side is voltage. How it gets there shouldn't be an issue. Correct voltage regulator adjustment might be a problem- - - -correct regulated voltage against a fully charged 12V battery needs to be 14.5-14.7 volts.
Carburetion specialist
We have helped LOTS of customers with generators, pertronix, and "carburetor idle issues" correct those issues simply by converting to an alternator.
If you are old enough, and grew up in rural America on REA electrical service, and remember the TV picture shrinking from both the top and the bottom when the refrigerator compressor kicked on, the above statement makes more sense.
Jon
The Carburetor Shop
I'm not considering doing any modifications or conversion to electronic ignition. It's just a question that popped into my head.
No. I've never seen or heard of a TV screen picture shrinking when the Fridge came on.
If you grew up in Atlanta, the electrical grid probably had sufficient capacity that you wouldn't see it.
In some of the older rural houses on REA, the picture would shrink from both top and bottom by as much as a couple of inches when the extra starting current from the compressor created a momentary low voltage. The dip would last maybe a second or two. Things electronic like stable voltage.
While the output from a generator might average the 14.5~14.7 volts Jerry mentioned at idle, the voltage isn't as stable as that from an alternator.
Jon
The Carburetor Shop
I'm from a suburb of Cleveland, Ohio but I never saw a tv do that. That sort of thing probably happened before my parents even met each other.
