1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1588511 09/28/2025 5:47 PM
My 1940 half ton is still running on the original engine. Now, after all these years it has a water leak. It appears to be coming from the water pump. I'll remove some panels tomorrow to get a better look. My question for now is: Are all of the 216 water pumps the same, or at least interchangeable? If not, then what years would interchange with my 1940?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
Both the Filling Station and RockAuto show a break in water pump between 1940 and 1946 216's (RockAuto doesn't list one for 1940)
The Filling Station lists a rebuild service for 39-40 water pumps LINK, but you have to send your pump to them unless they happen to have them in stock. And there are some pumps they can't rebuild. Expensive in any case.
[on edit]Filling Station says all 216's use the same water pump to block gasket, so maybe the only difference is the size/position of the hose connection. Maybe a later and less expensive new pump could be adapted with a little hose modification. Don't know for sure.
Up through 1940 Chevrolet used a single main water transfer port.
Starting in 1941 they went to two.
See picture.
My Blog
Well, that answers the interchangeability issue. Looks like the Filling Station's water pump to block gasket listing is a little misleading. Link
I knew someone would have the answer.
Yes, that really does answer the interchangeability question. Although, not in the way I had hoped. Thanks guys !!!
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
I had mine rebuilt by the Flying Dutchman. Then and Now Automotive also rebuilds them. I've used both companies and am happy with both.
1950 Chevrolet 3100 (Ol' Roy)
Thanks for that information. There is a Flying Dutchman who is a member of the stovebolt group. Is that who you're talking about?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
Mike - Here's the Flying Dutchman's Web Page along with a screen shot showing his contact info below. Not the same individual that registered back in 2000 and has never posted. frown
~ Dan
1951 Chevy 3 window 3100
