7 members (tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Who has the least expensive metal shears that will work for 16 gauge metal? Also a sand blaster that will work on a compressor that will provide max 125 psi. Thanks
Ridge dweller
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ridgeview, Most pneumatic shears can't handle 16 gauge, and many people don't like the finish a nibbler gives. I have enclosed a link to a electric shear that is cheap, and will probably do the job on a hobby basis. This type of shear is cool because you can follow a curved line. The crucial thing on the sandblaster isn't PSI, but CFM. If you have a small compressor, the syphon type blaster can do light work and not kill the compressor. A pressure pot style unit will make easier work of sandblasting, but will use gobs of air, and is best suited for a larger compressor. Check the CFM rating of various types of sand blast units and compare it to your rig. A fairly good gauge is 1 HP (electric motor) equal about 3 CFM of pump output. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92115 Stuart | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 |
Ridge dweller
| | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Tractor supply sandblaster. | | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | What gauge steel is used on the 54 GMC anyone?
Ridge dweller
I have seen 19 gauge mentioned most frequently. Although not a common number, maybe Detroit had 'buying power', or maybe they owned the rolling mills. This gauge is about .042 thick.
Stuart | | |
