0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#158814 02/04/2007 10:33 PM
Who has the least expensive metal shears that will work for 16 gauge metal? Also a sand blaster that will work on a compressor that will provide max 125 psi. Thanks
Ridge dweller
ridgeview,
Most pneumatic shears can't handle 16 gauge, and many people don't like the finish a nibbler gives. I have enclosed a link to a electric shear that is cheap, and will probably do the job on a hobby basis. This type of shear is cool because you can follow a curved line.
The crucial thing on the sandblaster isn't PSI, but CFM. If you have a small compressor, the syphon type blaster can do light work and not kill the compressor. A pressure pot style unit will make easier work of sandblasting, but will use gobs of air, and is best suited for a larger compressor.
Check the CFM rating of various types of sand blast units and compare it to your rig. A fairly good gauge is 1 HP (electric motor) equal about 3 CFM of pump output.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92115
Stuart
Thank you "Atomarc"
Ridge dweller
Tractor supply sandblaster.
What gauge steel is used on the 54 GMC anyone?
Ridge dweller
ridgeview,
I have seen 19 gauge mentioned most frequently. Although not a common number, maybe Detroit had 'buying power', or maybe they owned the rolling mills. This gauge is about .042 thick.
Stuart
Moderated by  MNSmith
