6 members (Rustnut, Bill Hanlon, texas46, DadsFirstPickup, 32Fordpuchoptop, 1 invisible), 147 guests, and 4 robots.
Topics128,108
Posts1,056,236
Members48,437
#1587957 09/20/2025 5:17 PM
I have an old Mac double flare kit that has served me well making brake lines and even 5/16 fuel line. Nothing fancy, but seems well made relative to the cheapo ones I’ve seen.
Trying to double flare some 3/8 last night and again today. Can’t do it to SAVE. MY. LIFE. Tried everything I can think of to get it wicked tight. Went and bought some NiCopp thinking that would make life easy. Line slips on the first operation (using the little die) no matter what.
Very angry. Walking away for a while.
1951 3100
Use a C clamp on the flaring blocks to be sure you get a good grip on the tubing. I've had to do that when double flaring 3/8" and 1/2" steel tubing at times.
If it's the type that uses two beams clamped together with wing nuts, that can be problematic, as the larger lines take more pressure. In the bigger sizes, they only really work well for pure copper lines, but you don't want to use that for brake lines.
If you want to be frustrated, try working with 1/2" steel tubing like is used for the oil pickup lines on our engines. I fought with converting to a higher capacity oil pump and the tubing to connect it to the pickup screen for quite a while until I got it. I had to fabricate a tool to make the bends. Fortunately it used compression ferrules instead of flare connections.
Saw one suggestion online to file/sand the the two beams on the surfaces that touch each other. Remove a bit of material so that they don’t meet all the way up.
1951 3100
Along with the other suggestions, some oil between the swedge and tube will help.
Kevin, I've found that cupro-nickel tubing has plenty of pressure capacity, so using steel at the oil pump is sort of a moot point. C-N is a LOT easier to bend and flare.
Jerry, I don't disagree that CuNi has the pressure capacity needed, but I repurposed the existing steel tubing from a couple engines I had on hand for replumbing the upgraded oil pump. I would have had to go buy CuNi tubing. As a matter of fact, even copper tubing has the pressure capability for the oil system, which operates a LOT lower pressure than a brake system.
Did that, and so many other little things trying to make it work.
1951 3100
