0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | I have and old Sears compressor that would not start someone said it might be the starter coil on the electric motor ..so i replaced it but could not get one as long as the one that came on it .it starts up now ..but when the air pressor get down to where the motor should kick on it wont start back i have to switch it back on by hand ! any one know if this due to the starter coil being to small are the switch is bad it's a reall pain in the butt to do this ever time ! :hammering: | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bowtiedaddy,
I think the item you are talking about is the starting capacitor. They shouldn't be hard to size for the motor and starting load. I will bet your problem is with the centrifugal switch located inside the motor.
It has a set of contacts that switch the start capacitor out of the circuit after the motor gets up to speed. When the motor shuts off, the contacts are suppose to come together and put the capacitor back into the circuit for the next start.
Either malfunction will not allow the motor to start. The air compressor has to unload after it stops too, which gives it a fighting chance when it starts back up...it can't start with cylinders loaded full of compressed air.
The new capacitor should have been the same physical size as the old one. They have values printed on their case...voltage and capacity in micro-farads...try to get one the same size and see if that solves the problem. If it isn't the capacitor, it's the centrifugal switch. Good luck.
EDIT. There is another possibility..the pressure switch isn't closing properly and telling the motor to start..so I guess there are three options, bad start capacitor (too small), bum contacts or sticking centrifugal switch, OR defective pressure switch.
Stuart | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | Thank you Stuart for the info on the compressor .don't know much about them and the info you gave me was real helpful ,,now i know what to try any way ......
Bob | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Capisitors can be different sizes, just insur that the voltage and MFD's are the same. MFD'S can be some what larger but volts should be the same. | | |
