2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | How do I tell what size the clutch head is? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Did they use clutch heads on '60 models? it usually goes 1/8 , 3/16 , 1/4 ,5/16 ,etc... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's only 3 sizes commonly used, most are the 2nd smallest
Bill | | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | Originally posted by delux54panel: Did they use clutch heads on '60 models? it usually goes 1/8 , 3/16 , 1/4 ,5/16 ,etc... Yep,they sure did.What I was wondering tho is how to measure the size of it to find out what I need.Do I measure the long side? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Aug 2006 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 98 | | | |
