7 members (baldeagle, TUTS 59, niobrarafun, Nick in Manitou, lumbersawyer, SmalltownTRKGuy, 55shaker), 108 guests, and 2 robots.
Topics128,195
Posts1,057,378
Members48,469
Hi. I have a 1964 C 30 Chevy Panel, I would like to change the single master cylinder, to a duel one, any suggestions as to what I can use to change to the dual one, my 64 has drum brakes, so if anyone here knows, please let me know
Wylie johnson
Dual Reservoir was mandatory in 1967. Start with a '67 or '68 Chevy panel truck system designed for 4 wheel drum brakes.
1950 Chevrolet 3100 (Ol' Roy)
wylie - Your topic is best asked and discussed in the Driveline forum, so your thread has been moved there for further conversation and help. smile
~ Dan
1951 Chevy 3 window 3100
1 Offline
I would check into a power brake setup and an adjustable proportioning valve. You can rent a double flaring tool to flare brake lines at many of the auto parts stores and there is no charge when it is returned.
The PB conversion would be my recommendation as well.
Fred
1 Offline
I believe the rental time for some of the parts houses is 48 hours.
