7 members (tclederman, Stovebolt48, Phak1, joe apple, Jon G, sron48, MickeyP), 74 guests, and 0 robots.
Topics128,188
Posts1,057,333
Members48,469
delete
Delete this forum
Save all you can from the donor, I used the s10 steering coloumn and it works great and then you can get a painless harness to match right up to it, piece of cake for signals and wipers and dimmer ignition maybe others I put electric wipers in mine, I can get you the name of the place I got them from if you want. I am putting electric windows in my coe also, can get you that info also. Are you going with the crank out windshield? It is pretty easy to just glue one in solid, no leaks.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
delete
Guess there was no saving that S10 box after you tore it into flinders 😂. It was probably fun to go at the S10 with your saw, but not as much fun disposing of the carnage. Good start, I’ll be following along.
1950 3100w/63K
Farm Truck: Fame-up restoration / modification
Follow the restoration story in his Project Journal
1950 Styleline Deluxe Coupe w/93K
How close are the wheelbase and track dimensions between the two?
1950 Chevrolet 3100 (Ol' Roy)
AD Addict & Tinkerer
P Online: Content
I’m glad you started a journal documenting your journey. It will be both educational and fun following your build.
Phil
Project Journals
Stovebolt Gallery Forum
delete
delete
Moderated by  J Lucas
