0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2025 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2025 Posts: 21 | delete
| | | | | Joined: Jul 2025 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2025 Posts: 21 | Delete this forum
| | | | | Joined: Nov 2005 Posts: 1,557 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,557 | Save all you can from the donor, I used the s10 steering coloumn and it works great and then you can get a painless harness to match right up to it, piece of cake for signals and wipers and dimmer ignition maybe others I put electric wipers in mine, I can get you the name of the place I got them from if you want. I am putting electric windows in my coe also, can get you that info also. Are you going with the crank out windshield? It is pretty easy to just glue one in solid, no leaks.
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2020 Posts: 277 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 277 | Guess there was no saving that S10 box after you tore it into flinders 😂. It was probably fun to go at the S10 with your saw, but not as much fun disposing of the carnage. Good start, I’ll be following along. | | | | | Joined: Oct 2021 Posts: 7,030 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,030 | How close are the wheelbase and track dimensions between the two?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2019 Posts: 4,538 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,538 | I’m glad you started a journal documenting your journey. It will be both educational and fun following your build.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jul 2025 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2025 Posts: 21 | delete
