3 members (Hotrod Lincoln, Pete O, 1 invisible),
309
Mod | | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Looking at 6v electric fuel pumps. Most say they're rated at 6 psi. Is this too much?
Thanks | | | | | Joined: Oct 2019 Posts: 401 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 401 | i have a regulator on my Beetle to get the pressure down to 2.9 psi as that is where it runs best. It is a Holley manufactured unit. | | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | | | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | Yes, 6psi is way to high.
The factory specs are 2-4 psi . More than that will over power your carburetor's needle valve and flood your engine.
My fuel pressure is 2.5psi at the carburetor.
1950 Chevrolet 3100 (Ol' Roy)
