7 members (Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna, klhansen, joe apple), 153 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#1586968 09/09/2025 3:28 PM
Can someone out there tell me what's your experience with Polished Bed Strips or Angles hold up to environment hot / cold?
I recognize ideally stainless steel is best.
O Online: Content
If you're going to use your truck as intended, buy steel ones and paint them like General Motors did when it was new.
If you're installing a bed that looks like a dining room table, what difference does it make? You're not going to be driving in the rain or scratching them up with cargo.
1950 Chevrolet 3100 (Ol' Roy)
I had a good laugh with your response. I understand perfectly your thought.
I’m kinda of the opposite opinion. If you use the truck and drive in the rain then stainless is the way to go. If it’s a museum piece then painted steel is fine. The op asked for opinions based on experience. Polished stainless strips in my truck, looks good after 10 years and 50k miles, rain or shine.
Mark
I went with stainless bed strips and they've held up really well. My truck has seen heavy rain multiple times, even snow and the bed is often used/loaded up.
The oak bed wood gets beat up and requires a quick sanding/staining but the stainless strips are pretty low maintenance.
1940 1/2-ton
Low skill and low buck build
Follow in the Project Journals
In the dark of night, she's a looker.
Stainless strips in my bed 25 years old. Strips still look new. No heavy usage.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
