11 members (KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, 2 invisible), 186 guests, and 2 robots.
Topics128,165
Posts1,056,992
Members48,458
ODSS President
ODSS President
There is a breach in the #5 cylinder, coolant leak. Might be able to get away with a #5 cylinder sleeve but that remains to be revealed. There was a ton of work to get to this point. Going to call around the regional machine shops, ideas and brainstorming welcome.
The local machinist I used for my head has a waiting list for engine work. Going to be on the phone tomorrow for other machinists to see if I can get the block done sooner. Talked yesterday with Jerry who offered up wise advice and support, wish I lived closer.
~ Cosmo
1949 Chevy Half Ton
Cosmo,
the breach is actually in the cylinder wall? I thought you had that at a speed shop prior for a going over.
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
ODSS President
ODSS President
The block came from a reputable machine shop. Can’t recall if they Magnaflux the block, if they did, they didn’t see the issue. The reason why it took so long was that my truck at the time was a daily driver only vehicle for 18 years and I had a perfectly running 235. I finally committed to the 261 and found the problem much too late. I’m sure if I had put together the engine, then had the issue, the machinist would have made good on the block. Too late after all this time.
~ Cosmo
1949 Chevy Half Ton
That’s terrible Cosmo! But, I’m pretty sure that a mutual friend might have one or two lying around somewhere! As a matter of fact, I just talked to him yesterday. He’s also in the nor-eastern area of the ODSS as I.
Jim
In the DITY Gallery
V
VEW Offline
V Offline
Bummer! Plop your 235 back in there 😊
~ Victor
1957 3100 - moved on
ODSS President
ODSS President
Sold to a good man.
~ Cosmo
1949 Chevy Half Ton
Prayers sent.
I do mean that.
Wish I had more to offer, but my local reputable old engine mechanic retired.
Moderated by  Bill Marlow, SWEET
